YupDoes the internal beam height adjuster still work or are these fixed in place?
I thought that was only on a reflector headlight, if the unit is already a projector i assumed a HID kit would be fine ?Aftermarket HIDs are now an MOT failure.
Has anyone had these THQ lights apart?
I'm weighing up options of how to get the best light output for sensible money and am considering swapping out the projectors for bi-xenon ones, fitting a HID kit and LEDs in the main beam chambers for flashing duties. That way I'll get a HID main beam without the warm up delay and a fast responding, white flasher for when the lights are turned off. From what I can gather, aftermarket bi-xenon projectors are fixed through the bulb hole on regular reflector lights, so I'm wondering if it would be a relatively straightforward swap.
That all looks pretty involved. Unless someone can tell me how THQ supplied headlights come apart, I shall be fitting bi-xenon projectors into my H7s. Something needs to be done as they are dire. Something along the lines of these
US $71.39 15% OFF|SINOLYN 2.5 inches HID Bi xenon Headlight Projector Lens LHD/ RHD Full Retrofit Car Styling Kit Lenses H4 H7 4300K 6000K 8000K-in Car Light Accessories from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
Why xenon at all? If you want to go "value for money" way, I would consider installing original VW T6 LED units
https://www.t6forum.com/attachments/img_20171022_204922-jpg.42735/
inside of twin H7 head lamp.
@Morzze has done already something similar.
None I don’t think mate, I’ve just got the V2 fitted by THQ and there great, Jack couldn’t be more helpfulLooking at the THQ lights, apart from the sequential indicators is there any difference between V1 and V2?
