Haven’t looked to be honest but if it’s h7 then I have no where to go. I just know I have never had a vehicle with such shit lights and I have had a lot of vehicles.What bulbs do you have now, H4 or H7 ?
Pete
Yes.Are Caravelle H7 headlights much of an improvement on standard T6 headlights?
To be honest, I have not tried standard H7 (Caravelle) as I upgraded the bulbs when I installed them, but a AAA led headtorch strapped to your head would be an improvement on the H4s with standard bulbs.
You have the standard H4 headlights. There is a massive amount of info on this forum which will describe your various options, pros and cons etc, it would be pointless for me to go on about it here, the search button will reveal all!I wonder if 'The Forum' could talk me through headlight upgrades....I don't even know for sure if the ones fitted are 'standard', but driving home tonight in the sh*te weather they seemed pretty awful!!
So assuming they are 'standard' and going from there in terms of ease/cost please.....(I know nothing)....
Many thanks fellow van-ites!!
I also had standard H4's on mine, I also wanted to upgrade so basically you've got 3 choicesI wonder if 'The Forum' could talk me through headlight upgrades....I don't even know for sure if the ones fitted are 'standard', but driving home tonight in the sh*te weather they seemed pretty awful!!
1. H4 upgraded bulbsI wonder if 'The Forum' could talk me through headlight upgrades....I don't even know for sure if the ones fitted are 'standard', but driving home tonight in the sh*te weather they seemed pretty awful!!
Great minds & all that pal1. H4 upgraded bulbs
H4 Headlamp Bulb Upgrade
I really want to upgrade my headlight bulbs. Going to do this when she goes in for her check up.www.t6forum.com
Makes a big difference. Goes from shocking to acceptable. I used Philips ExtremePro 150, others have used Osram nightbreaker, have a search through the forum. Cheap to do!
2. H7s
H4 To H7 Upgrade
Replaced my standard H4 headlights on my 17 plate kombi highline with genuine H7 headlights from a 17 plate Caravelle. It's literally just plug and play, no warning lights, no VCDS, just swap and go. Does require removing the front bumper but really not as bad as it sounds. IMO the H7's are...www.t6forum.com
Need to find a set on ebay or similar, anywhere from £ 150 to 300 second-hand. There is a guide somewhere on here with pictures of all 3 lights, you will soon be expert in identifying the standard H4s on ebay posted for ridiculous amounts.
Need to remove the bumper, but easy enough to do, just follow the thread and the Transporter HQ video. May as well upgrade the bulbs as well while you put them in.
3. THQ and other (same?) lights
You can get them new or second-hand, several places seem to do the same types. v1, v2 and v3 depending on the indicator. They have a LED strip-type DRL, and I think the dipped bulb is an H7, so probably on apar with #2.
4. OEM LEDs
Few £thousand, either professional retro-fit or DIY. A good thread on the forum describes it.
5. LED bulbs possible as an improvement in options 1-3
Not road legal, possible MOT fail, but a common option, again, lots of advice on the forum.
FINALLY
If you are fully loaded or converted, make sure you adjust them upwards with the rotary thingy!
EDIT: pipped at the post by @Superowls
Awesome thanks guys....just the ticket. I shall have a read and do some research.
Ahha...Making a lot of sense now, thank you @CAB.
Set of H7s on ebay:
Genuine VW Transporter T6 Headlights H7 Twin Reflector Shuttle SE Caravelle | eBay
Find many great new & used options and get the best deals for Genuine VW Transporter T6 Headlights H7 Twin Reflector Shuttle SE Caravelle at the best online prices at eBay! Free delivery for many products!www.ebay.co.uk
