[GUIDE] How to retrofit LED projectors to T6 H4 headlights on a VW Transporter
Andysmee
Previously the last of the TSI's
Moderator
T6 Legend
Thanks to @Robert and others on this thread:
Fitting retrofit LED mini-projectors to H4's is now completely doable, and very good value for the light output: (H4 LED mini-projector on the left, H4 halogen reflector on the right)
The projectors I used are these ones: Bi-LED Projector Lens Car Headlight 1.5’’ H4 9003 Canbus Cooling Fan Retrofit | eBay
I test-fitted the passenger side on the van but to fit the ballast you need to remove the headlights from the van.
I started by fitting Osram LEDs for the DRLs:
I did a comparison of Osram and Philips replacement LED lamps, to get the DRL out you twist the fitting a quarter turn anti-clockwise and it pops out.
On to the main event, first remove the halogen H4 bulb by pulling the connector off the back, pushing the spring clip in and to the side and remove the bulb.
Now you need to remove the lamp guard with a small torx bit.
Then cut off the guard to retain the mount for the spring clip. It doesn't matter how far in you cut, it still falls apart as it's not soldered together.
It re-attaches to the reflector which holds the two parts back together. While we're on the subject, try not to let any dirt or debris fall into the headlight. If it does, turn it upside down and shake it back out.
Now we need to squeeze the ballast into the housing in the void behind the reflector. Wind the adjustment screws using a cross head or hex driver until the ballast slides in. I had to shave a tiny piece of plastic off one part of the housing on one side, using insulating tape as a sticky trap to catch the debris.
I've fitted the ballast with the H4 connector end wrapped over the top of the (in-out) adjustment screw post.
Attach the H4 connector to the standard wiring and push the connectors into the space on the outer side of the headlight.
Next move to the mini-projector. Remove the fan module from the end of the bulb assembly, after disconnecting it.
Undo the two screws holding the H4 template to the assembly and move to the anti-clockwise setting. This makes the following change on this kit:
Now insert the bulb into the headlight and thread the cables through the spring clip:
Fully seat the bulb and latch the spring clip onto the hook.
Connect the bulb connector to the ballast and screw on the fan module and reconnect to the bulb. Tuck all the wiring away (I used the sidelight wiring to keep the bulb wiring hooked down).
On a side note, the side light LED has polarity so you won't know if it's connected right until you put the headlight back on the van. Be ready to test it before bolting in the headlight.
Close the cap on the back of the headlight and it's ready to fit back on the van.
Here's the interior of the headlight with the cut down headlamp guard peaking out.
Here's the passenger side headlight, a mirror image of the set above.
Here's the dipped beam pattern after a quick adjustment. A visit to an MOT centre should sort it out later.
This is the LED full beam pattern (on left) with halogen H4 on the right. And DRL with sidelights comparison above (LED vs incandescent).
Good, huh? :cool:
Can't have too many pictures, I'm sure!
Oh dear, finally started the engine after buying a charger and, guess what? Bulb out warning light :confused:
First drive out with them and the lighting is very good, but alignment not right, expecting to be flashed any moment.
  • Sad
Better news. I started diagnosing the lamp warning light by swapping back in my old bulbs and got lucky, it's the Osram DRL LED bulbs that are causing the warning light, not the H4's, or the Osram LED sidelights.
But I think my DAB reception is affected by the H4's when I drove out the other night, whereas today I drove in daylight and no problems. It's not catastrophic, but definitely weaker signal on 6Music which tends to have patchy reception.
  • Wow
Reactions: mmi
What's your BCM coding?
There might be some tweaking/improvements possible.
Reactions: mmi
Get someone local to read your BCM (body control module, address 09) coding, using one of the following: Vcds, OBDeleven, CARISTA, etc.
Reactions: mmi
Okay. Does that mean I don't need to go looking for a solution to the LED DRLs?
Any update on this?
It will take me a while to get a BCM readout but in the meantime I've driven it again in the dark and the lighting is fantastic. Still a fantastic result for the money, but I found that the stereo won't hold a DAB station when you move cell unless you turn off the H4's, but then will hold the reception until you leave an area again. And the lamp warning light is fine and not related to the H4's.
So, with that in mind, I would still recommend trying them, rather than several hundred on THQ ones
Awesome thread @Andysmee. I've never seen these mini projector LEDs before. Just ordered some from the 'bay.
I'm surprised adjustment of the threaded body affected dip beam so much, as they're projector. I can see it changing main beam, as that looks like it uses the headlamp reflector itself. Anyways, will get to play myself in a few weeks, as the lamps are coming from the Far East somewhere.
From the other thread, I was going to try the Retrofit Labs HIDs, but didn't think the headlamps would come apart that easily. Glad I think I've finally found a fix for these woeful H4s.
It depends what your current BCM coding is.
Code:
Car: Volkswagen Transporter
Year: 2019
Body type: VAN
Engine: CJKB 110 kW (150 HP) 2.0 l
Mileage: xxxxx
01 Engine
Trouble codes:
No trouble codes found
03 Brakes
System description: ESC
Software number: 7E0907379P
Software version: 0133
Hardware number: 7E0907379M
Hardware version: H06
Serial number: 60059000001762
ODX name: EV_Brake1ESCCONTIVN75XGP2
ODX version: 011001
Long coding: 517E4398256984858A78C279A48821A679F100
Trouble codes:
04 Steering Angle Sensor
System description: LENKW.SENSOR
Software number: 6R0959654
Software version: 0070
Hardware number: 6R0959654
Hardware version: H07
Serial number: 06121813471540
ODX name: EV_LWSKLOVW25X
ODX version: 005001
Long coding: 01
Trouble codes:
08 Air Conditioning
Trouble codes:
09 Central Electrics
System description: BCM PQ25 Max4
Software number: 7E0937090D
Software version: 0762
Hardware number: 7E0937090D
Hardware version: H82
Serial number: 8601 008190822
Long coding: E0A4303A0A212431002009742C2B8C540FC0708F60444D60330400220800
Subsystems:
System description: J386__TSG_FT
Software number: 7E0959801R
Software version: 0653
Hardware version: 005
Serial number: KU0KU009011990090700
Long coding: 1400B1
System description: J387__TSG_BT
Software number: 7E0959802Q
Hardware version: 004
Serial number: KU0KU007011990073892
Long coding: 0400A1
Trouble codes:
02745 - Left daytime running lamp bulb Open circuit/short circuit to B+
static
02746 - Right daytime running lamp bulb Open circuit/short circuit to B+
static
10 Parking Assistance
Trouble codes:
13 Adaptive Cruise Control
Trouble codes:
15 Airbag
Trouble codes:
17 Dashboard
Trouble codes:
19 Gateway
System description: GW-K-CAN TP20
Software number: 7E0909901
Long coding: 042305
Trouble codes:
25 Immobilizer
Trouble codes:
5F Multimedia
Trouble codes:
61 Battery Regulation
Trouble codes:
You could change your original BCM(09 Central Electrics) coding from
to
E0A4303A0A212431002009742C2B8C54D0C0708F60444D60330400220800
This adjustment will eliminate BULB FAULT light in IC and should reduce interferences on DAB.
to
This is how OBD11 displays it, can you elaborate?
Original BYTE 16
(0F)16 = (0000 1111)2
bit 0 = 1 Activation of low beam via pulse width modulation (PWM) active
bit 1 = 1 Activation of fog light via pulse width modulation (PWM) active
bit 2 = 1 Activation of Daytime running lights via pulse width modulation (PWM) active
bit 3 = 1 Activation of High Beam via pulse width modulation (PWM) active
bit 4 = 0 Lamp Diagnostics for Low Beam inactive
bit 5 = 0 Lamp Diagnostics for Rear Fog Light(s) inactive
bit 6 = 0 Lamp Diagnostics for (Separate) Daytime Running Lights (DRL) inactive
bit 7 = 0 Lamp Diagnostics for High Beam inactive
Proposed modification to BYTE 16
(same description of bits applies as above)
(D0)16 = (1101 0000)2
bit 0 = 0
bit 1 = 0
bit 2 = 0
bit 3 = 0
bit 4 = 1
bit 5 = 0
bit 6 = 1
bit 7 = 1
Reactions: mmi
Regarding PWM you can have a look what it does when activated below.
Reactions: mmi
