See if you can find some later edition genuine OEM H7 headlight units for sale…. normally around the £200 mark. With a good set of H7 bulbs these will be a massive improvement without breaking the bank.I’ve got a T6 140. The headlights are dangerous. 60mpg on an unlit road and can only see about 30m in front - can’t see upcoming bends in the road. Genuinely dangerous!
Can’t afford anything fancy. What’s my best option? Nightbreaker bulbs?
I’ve moved your post from the ‘interiors’ to the ‘lighting’ sub-forum and subsequently merged it with this, as (you’re finding out) it’s unfortunately another case of thr H4’s falling far below expectations. A quick search will show you it’s been asked before!I’ve got a T6 140. The headlights are dangerous. 60mpg on an unlit road and can only see about 30m in front - can’t see upcoming bends in the road. Genuinely dangerous!
1. H4 upgraded bulbs
H4 Headlamp Bulb Upgrade
I really want to upgrade my headlight bulbs. Going to do this when she goes in for her check up.www.t6forum.com
Makes a big difference. Goes from shocking to acceptable. I used Philips ExtremePro 150, others have used Osram nightbreaker, have a search through the forum. Cheap to do!
2. H7s
H4 To H7 Upgrade
Replaced my standard H4 headlights on my 17 plate kombi highline with genuine H7 headlights from a 17 plate Caravelle. It's literally just plug and play, no warning lights, no VCDS, just swap and go. Does require removing the front bumper but really not as bad as it sounds. IMO the H7's are...www.t6forum.com
Need to find a set on ebay or similar, anywhere from £ 150 to 300 second-hand. There is a guide somewhere on here with pictures of all 3 lights, you will soon be expert in identifying the standard H4s on ebay posted for ridiculous amounts.
Need to remove the bumper, but easy enough to do, just follow the thread and the Transporter HQ video. May as well upgrade the bulbs as well while you put them in.
3. Aftermarket headlamp replacement
Which? Aftermarket Headlight choices
Which? ************************************************* UPDATE: See this post: Headlight upgrade choices ************************************************* Vee Dub Headlights T6 Chrome LightBar Headlights - Vee Dub Transporters T6 Forum Shop Genuine VW T6 Replacement Front Headlight Unit -...www.t6forum.com
You can get them new or second-hand, several places seem to do the same types. v1, v2 and v3 depending on the indicator. They have a LED strip-type DRL, and I think the dipped bulb is an H7, so probably on apar with #2.
4. OEM LEDs
T6 OEM LED-headlight retrofit
I had HazzyDayz do the LED upgrade for me last week. Amazing the difference.www.t6forum.com
Few £thousand, either professional retro-fit or DIY. A good thread on the forum describes it.
5. LED bulbs possible as an improvement in options 1-3
Not road legal, possible MOT fail, but a common option, again, lots of advice on the forum.
FINALLY
If you are fully loaded or converted, make sure you adjust them upwards with the rotary thingy!
I have no idea how “stuff” works! You mean my existing lights on my 16 plate t6?If you have H7 light I’ll take them off you
Believe me - it’s not an ‘age’ thing - H4s are pants!!Hi all, I’m looking to “upgrade” my front lights to led, I didn’t realise how expensive they are! I’m still going to go ahead but wondering what are the best as I think there are different types? I just need to see better at night when driving! (It’s an age thing )
Can someone tell me what the brightest lights are and what they are called? Btw…I’m not mechanically minded at all, I will need to ask my local garage to fit them as soon as I know what to get!Believe me - it’s not an ‘age’ thing - H4s are pants!!
Get ready for at least 20 different opinions, factory OEM LEDs are probably the best, you’re talking serious ££££Can someone tell me what the brightest lights are and what they are called? Btw…I’m not mechanically minded at all, I will need to ask my local garage to fit them as soon as I know what to get!
Anything other than factory LED I wouldn’t bother, just my experience with prev retrofit on my last T6Can someone tell me what the brightest lights are and what they are called? Btw…I’m not mechanically minded at all, I will need to ask my local garage to fit them as soon as I know what to get!
It’s hard to say, without knowing what your budget is and whether your garage is capable of an OEM retrofit (which is the brightest) or just a spanner-job headlight swap (which isn’t, but is an improvement).Can someone tell me what the brightest lights are and what they are called? Btw…I’m not mechanically minded at all, I will need to ask my local garage to fit them as soon as I know what to get!
And as @DXX said, there’s plenty of info on this topic if you have a search.1. H4 upgraded bulbs
2. H7s
H4 To H7 Upgrade
4. OEM LEDs
Not road legal, possible MOT fail, but a common option, again, lots of advice on the forum.led bulb
www.t6forum.com
FINALLY
EDIT: pipped at the post by @Superowls
SearchHi everyone, first post for us…….
what’s the best recommendations for replacing the headlights on our 2017 T6, as the standard ones are like a couple of candles.
many thanks
