Reading back through this.
Have you remove pin 45 at the BCM? Also have you remove the wires at the plug behind the steering wheel where you fitted pins 9, 10 & 11?
If not this could be the issue. It may still be seeing the stalks.
Hi
I have a 2016 T6 with a steering wheel without buttons. It's CCS on stalks. I have bought a complete MFSW Polo steering wheel so I wonder if I think correctly that I can skip steps in the user manual below since I have CCS.
Point 4 I reckon goes out?
I'm a little confused on what I really need to do on points 5 and 6.
Is there perhaps someone who can explain exactly in relation to a car with CCS
4 - Get Access to the T10 connector under the battery
If you are lucky and already have CCS then you can skip this otherwise putting the wire into the T10 connector is the hardest part of the installation.
Remove the battery and the covers below it.
There you will find an enormous bunch of wires and connectors along with the ECU. Of course the T10 connector is right at the bottom.
I found the easiest way to get at it was to disconnect all the connector above it first. There are two black connectors so be careful. The one you want should have a black and yellow wire that it connects to the ECU pin 44 with. I also removed the glove box to help with the routing of the wire.
5 - Remove Redundant Wires from the Stalks Connector T41
The horn will now be operated by the LIN Bus so the brown and yellow wire has to be removed from pin 11 and insulated. This stops the horn sounding when the CCS on/off button is pressed.
If you have CCS on the stalks, and are not changing them to non CCS stalks, remove the six stalk CCS wires from pins 26 to 31 and insulate them. Remove the black and yellow CCS wire from pin 45 on the BCM connector T73b.
6 - Install the 3 Repair Wires
First Run two wires from the stalks connector T41 pins 9 and 10 to the pedal area.
If you already have CCS, reuse the black and yellow wire from pin 26 or 29 (they are connected) for pin 11 and another disconnected wire (I used the blue wire from pin 31 don't use the other black and yellow wire) for pin 11 (wires from pins 9 and 11 should now already be installed).
Pin 9 wire needs splicing into the black wire on the light switch connector. Take extra care with this one as if it fails your lights may go out.
Pin 10 wire needs splicing into the wire for pin 36 in the BCM connector T73b
Pin 11 wire goes to pin 1 of the T10 connector under the battery. I routed it through a blanked hole near the wheel arch, that I think would be used for the bonnet release cable on LHD vans. Then I drilled a hole to get to the T10 connector. The loom I had for the old CCS kit just reached the T10 connector.
Regards
Joar
