I am sort of with you in way. I can see the point of having staggered wheels, if it gives the rear wheels a greater dish than the front (for looks).Why do people fit wider rims / tyres on a van? I guess purely looks? From my perspective and my motor racing experience it has zero advantage to any handling characteristics. A van on a really good suspension set up with narrower rims and 40 /45 profile tyres will handle way beyond most drivers capabilities on the same size all around. Comfort is always compromised with really low profile tyres and wide rims that are not designed for a van in the first place. I love to see the show vans they look amazing. Each to their own. Enjoy![]()
What goodyear tyres are these
That looks spot on, cheers.I have 245 45 20 all roundView attachment 294002
How you finding them ? Thinking of getting a set when current set need changing.Goodyear Eagle F1 Asymmetric 6’s.
Compared to the original 275/40R20’s the conversion company fitted to my van, these in 245/45R20’s are light years ahead. The drive, overall handling and road noise are miles better. Would recommend them.How you finding them ? Thinking of getting a set when current set need changing.
I’ve only had my van since the end of March this year. Always had hot hatches prior to the Transporter, so know only too well that you need good tyres under you. My wheels are only 8.5J and I soon learnt that 275 tyres are too wide for this width of wheel, that being said, a lot of conversion companies still fit them. My original tyres were brand new when I bought the van, but the road noise and handling was horrible. Yes, I know it’s a big heavy van and not to be compared to a hot hatch, but after changing the suspension to Bilstien B14 Komforts, I noticed slight rubbing on full lock, especially in reverse. The new tyres have made a massive difference and I intend to use them on the van all year round. I don’t fly around in the van, but having a narrower and better tyre on the van has made the steering more precise and the overall driving experience worth the expense.I have 275s on mine from.when I bought the new wheels last year. Do you use them in winter as well? Heard they have good wet handling conditions on them?
Excellent review fair playI’ve only had my van since the end of March this year. Always had hot hatches prior to the Transporter, so know only too well that you need good tyres under you. My wheels are only 8.5J and I soon learnt that 275 tyres are too wide for this width of wheel, that being said, a lot of conversion companies still fit them. My original tyres were brand new when I bought the van, but the road noise and handling was horrible. Yes, I know it’s a big heavy van and not to be compared to a hot hatch, but after changing the suspension to Bilstien B14 Komforts, I noticed slight rubbing on full lock, especially in reverse. The new tyres have made a massive difference and I intend to use them on the van all year round. I don’t fly around in the van, but having a narrower and better tyre on the van has made the steering more precise and the overall driving experience worth the expense.
We never use 265 40 20 , the reason some do is because they cant find or be bothered to find staggered tyres for the staggered wheels , 265 Kinda fits 8.5 J fronts and 10 J rears and is less likely to touch on the front . 245 45 20 and 275 40 20 is the perfect balance , all the tyres look good on the rims the van will behave better be more responsive in cornering and there is less drag , generally feels much better .
265/40/20 is by far the best tyre for a Transporter that's not running staggered wheels (eg 9J all round) They are also 103 rated for T32. (Unless it's considerably lowered of course)
FYI most German wheel manufacturers get the TÜV approval based on a 275/35/20. They don't really get T32's over there though.
275/40/20 is ok ish on staggered rears, that's all. Being a 106 rated tyre they are a really hard, stiff walled tyre. The ride is very firm. I've known countless people drop to a 265/40 and find the ride massively improved. It grinds my gears when I see wheel suppliers fitting 275/40's. It's just lazy. They can say there are load rated for everything, and don't actually seem to care the ride is so hard. You ever seen someone commenting they hate their 20's because the ride is hard, you can guarantee they have 275/40's on.
275/40/20 on the front will also rub on bumpers, and on full lock plus puts your Speedo out by about 8%.
If you're low low, we worked with a factory to make a 103 rated 255/35/20. It's a budget brand but we've been really impressed with them.
The 275/40 is too big for a Transporter and only used because it’s cheap! (it’s an ex Range Rover size so plenty of availability) we never have used this size in 20 years of working with Transporters like most others in the know - it seems to be mainly the online retailers who sell wheel deals who use the 275/40! . It’s between 5.5- 8.3% bigger than the factory sized tyres (16&17”), lowering with a 275/40 on the front at any decent drop will rub! The only place for oversize is with a 17” wheel when lifting a van.
After speaking with Supermetal wheels the other day, they have already got TUV approval on certain certificates for 265/40. The 265 is less than 5% oversize than all the factory wheels so perfect.
For 4motion you can use 265/40 both front and back and lower with no issues and with a staggered setup as we’ve proved and you retain your VW warranty.
On a 2wd you can also run the 245/45 on the front, and then even with a slimmer front wheel than 9”, with a staggered rear and 265/40. The difference is less than 1.5% front to back so unnoticeable.
Obviously my post is for T32 - There are other options for T28/30 as suggest above by @Solow Suspension .
Pics so you can see they work as suggested
This is 9j all round 265/40 - Perfect
4Motion, 9j 265/40 all round
4motion van, staggered wheels with the 265 all round - perfect.
Excellent, thanks. I have run Nankang before but on cars and yes they are good for a budget brand.Nankang come up small which is why they are popular with the tuning scene as they allow for better fitment. I've ran NS2 on several cars and rate them well. I'm into my 3rd set of Accelera 255/40/20 and these some up smaller than premium brands. They also wear very well, around 30k to a set on a 100mm lowered Caravelle.
As a whole budget brands are generally smaller like for like. I guess they save on rubber!
I'm in 265/40/20 all round, 8.5" front 10" rest 4Motion. I'm looking at wheels as well and I did read somewhere that 255 was the maximum (recommended) width for an 8.5" rim job.There is so much discussion on here regarding wheels and tyres. I’ll give you my ten penny worth that suits me but will be not everyone’s choice. Vehicle is a T6.1 T32 SWB Kombi.
Wheels all around are 20” x 9” with 265 40 20 104y. Tyres are Goodyear Eagle F1 Asymmetric 5. Tyre pressures 36-38 depending on load. Suspension fitted by CRS adjustable Koni dampers with adjustable spring seats. H and R springs. I find this set up as good as you can get on 20”s without going to Air suspension. Your 8.5” rims I would say are a tad too small for 265s which will cause more movement in the side wall especially on turn in. Ride quality and performance is not just wheels and tyres it’s the complete suspension set up together with premium tyres and a decent laser alignment. I suggest speaking to Steve at CRS. Good luck.
Have a look for Vredestein all seasons. Best I have used, had them on a few cars.Not for a T6 or T6.1 but anyone any first hand experience of good all season tyres for 2021 Landrover Discovery. Currently had mid range tyres installed which needs replaced. Are Michelin cross climate 3 or 2 a good idea or is there any other brand anyone would suggest? Being a 3.0l V6 I'm not wanting to go down AT tyre route as would kill mpg even more. Current tyres R20 255 55 , 110W extra load
