Valence U27-12XP Lifepo4 Lithium Battery -- How We Done It --
with a lot of members having these batteries now, the other thread was being swamped.
so this is just about these batteries . . .
Lithium Werks provides safe, reliable and mobile energy solutions for energy storage Features
and transportation. The U27-12XP is a high-performance, 12 volt battery, built on a
patented Lithium Iron Phosphate chemistry platform providing over 1.8 kWh.
The U27-12XP is ideal for material handling, stationary energy storage, and commerical
EV or marine applications. The module’s inherent safety, long cycle life, and zero
maintenance offers end-users another alternative to other battery chemistries and
diesel powered solutions by replacing with this reliable lithium ion solution
Features
• >4000 cycles at 80% DOD
• Create systems 12 - 1000 V
• Series and/or parallel operation
• Automatic cell monitoring & balancing (edit: master BMS or software & cable reqd)
• Temperature monitoring of cells
• Rugged mechanical design
• Thread locking feature
• Footprint of Group 27 lead acid case
• Maintenance-free
No hydrogen generation or gassing
Efficient & Fast Charging
High charge effciency of >90%. Increases productivity, reduces energy costs and eliminates the need for investments in battery change out systems.
High, Uniform Discharge Voltage
Delivers stable voltage during discharge and
increases equipment performance.
Longer Life : Provides > 10 times the life of lead acid batteries.
Robust Safety: Multiple levels of protection prevent operation outside of current, voltage, and temperature limits. (edit: master BMS & disconnect relay reqd)
No thermal runaway
No corrosive acid leaks
No explosive gassing
Space and Weight Efciency
Systems provide >3 times the energy per weight of lead acid.
Environmentally Safe
Does not contain toxic metals such as cobalt, lead, cadmium, nor any corrosive acids or alkalis.
www.lithiumwerks.com
T6F members with these batteries: ( anyone else got one PM me and ill add you to list )
@Dellmassive
@Discobadger
@Hickey
@drew_greenday
@Kramsdog
@Jollyvan
@ACM
@MrGrout
@Eddie Sutherland
@Dilbert
@ched
@Sjbso2000
@Wills
@Jh001
@DXX
@Lowlec
@Deaks
@Brennanpj
@caerfilthy
@Cooper
@drew_greenday
@andys
@Tandem2
@Joe Richardson
@Marcovan8
From my experience these are the IMPORTANT FACTS ABOUT LITHIUM batteries:
DO NOT OVER CHARGE THEM, (USE A CHARGER FIT FOR PURPOSE)
DO NOT RUN THEM 100% FLAT, (TRY TO RECHARGE BEFORE 10-20%)
STORE THEM AT 50% IF PUT INTO STORAGE FOR A TIME,
USE THE CORRECT CHARGER / METHOD, (LITHIUM PROFILE OR SUPPLIED CHARGER)
DO NOT SUBJECT THEM TO HIGH TEMPS (IN VAN/CAR/TENT/CAMPER ETC) (KEEP BELOW 30degC) **** MOST IMPORTANT ****
DO NOT SUBJECT THEM TO VERY LOW TEMPS/FREEZING (IN VAN/CAR/TENT/CAMPER ETC) (below 0degC)
DONT LET THEM GET WET (IE OUT IN THE RAIN) UNLESS THEY ARE IP RATED
STICK WITH A KNOWN BRAND NAMES,
REMEMBER YOU GET WHAT YOU PAY FOR, SO CHEAP UNBRANDED IMPORTS MAY HAVE SUBSTANDARD PARTS THAT MAY HAVE FAILED QUALITY CONTROL WITH OTHER MANUFACTURERS.
STAY AWAY FROM LIPO CELLS. (older lithium tech)
More Info for people to compare:
here my batterys data . . . . .
i currently have the 6 below
Id3
id11
id7
id 10
id 4
have a look at this thread too, which uses these batteries . . .
www.t6forum.com
Features
• Maintenance-free
No thermal runaway
@Dellmassive
@Discobadger
@Hickey
@drew_greenday
@Kramsdog
@Jollyvan
@ACM
@MrGrout
@Eddie Sutherland
@Dilbert
@ched
@Sjbso2000
@Wills
@Jh001
@DXX
@Lowlec
@Deaks
@Brennanpj
@caerfilthy
@Cooper
@drew_greenday
@andys
@Tandem2
@Joe Richardson
@Marcovan8
Id3
id11
id7
id 10
id 4
12v Lithium Leisure Battery Box 138Ah 1766Wh -- How I Done It --
12v Lithium Leisure Battery Box 138Ah 1766Wh -- How I Done It -- It's about time that I got this long-overdue project sorted out. The missing parts are on order and completion is in sight . . . . . . . . ready for the Post Pandemic 2020 Camping Trips (Hopefully) This is where it started. p1...
