Battery Chargers - How I Did It -
Dellmassive
VCDS User
Moderator
T6 Master
So its that time of year again, cold, rainy. . . . . . . flat battery =[
This time we look at Battery Chargers.
Our vans will most likely come with a AGM style starter battery, for this type of battery we need a "Smart Charger" . . . . but what does this mean?
well, chargers of old were of the constant voltage constant current type affair.
They would put out 13.8v at say 5amps and that was it . . . . . . . .
Modern AGM batteries need a much smarter way of being charged properly.
Here’s an extract from OPTIMA:
Here are a couple of things to keep in mind when maintaining your Absorbent Glass Mat (AGM) battery,
Many newer battery chargers, , have microprocessors that collect information from the battery and adjust the current and voltage accordingly. Some have different settings for charging flooded, gel and AGM batteries.
All lead-acid batteries can experience sulfation—the formation of lead sulfate crystals upon discharge. Look for a charger with a desulfation mode to help condition your battery and keep it performing at its best.
Low and slow is best. A low amp charger (one to 12 amps) is generally the best choice for charging any lead-acid battery. It's quicker to charge at higher amperage, but it also can generate a lot of heat, which reduces the life of a battery, just like the heat of summer.
Alternators are NOT chargers. Don't rely on your alternator to do the work of a charger. If your battery is discharged to the point where it cannot start your vehicle, use a charger as soon as possible to make sure your battery gets fully charged.
So we need a decent modern smart charger, ok fine but which one?
well there are a few on the market, here are a notable few manufacturers that stand out.
CTEK - CTEK | Battery chargers for all types of vehicles
NOCO - NOCO | Start Dead Batteries
VICTRON - Victron Energy
They all sell smart chargers, they can be fitted with quick disconnects or be hard wired, they can also be installed permanently inside the vehicle also,
When permanently installed they will charge the battery when the van is connected to a EHU either onsite or at home, which is nice . . . . . .
some units like one from victron also do multiple outputs so the one charger can charger can charge the starter battery and also the leisure battery bank. . . . . very handy.
the quick disconnects are also worth looking into, also note that even though they all look similar disconnects from different companies do not work with each other. These are great for connecting the M6/M8 eyelets direct to the battery and then with an extension you can safely lock the van with the charger safely connected, these chargers can be left connected like this indefinably.
Other connection options are also available. You can get a 12v AUX plug to plug into the socket to indirectly charge the battery, though note 10Amps is normally the max current for that method.
OBD2 port connection is also an option, you can buy “memory savers” which is basically a way of back feeding power to the car/van via the “direct battery connection” of the OBD2 port while you change your main battery (just remember that the battery positive terminal cable will be live when you change they battery so make sure you insulate it!! I normally stuff the cable end into a leather glove so it can’t short out) . . . . . . . this method can be used to charge the battery too. I remember one T6F member stating that the VWCV guy had actually recommended this method as connecting a smart charger . . . . (Suppose it’s a kinda idiot proof solution) though again I would only use a low Amp charger as the OBD2 pin connection would not support the large current chargers.
So what charger do we need?
Smart Automatic Battery Chargers:
The basic stages of charging from flat, using an automatic type charger are:
Bulk Charge - During this process a constant current is supplied to the battery at a rate determined by the battery charger. Most automatic battery chargers will detect the type of battery being charged and apply an appropriate current at a constant rate until the battery is about 70% charged.
Absorption Charge - During this stage the charger maintains a constant voltage to the battery and the charging current tapers off naturally when the battery nears full charge.
Float Charge - When the current flow reaches a pre-determined set point which indicates the end of the absorption charge stage, the charger automatically switches over to float charge. The purpose of this stage is to simply maintain the battery at full charge.
Most modern battery chargers are of the automatic 3 stage type and will detect the type of battery under charge to adjust the above 3 stage charging process accordingly.
What Size Battery Charger:
As a general rule of thumb, when selecting a charger choose an approved battery charger equal to at least 10% of the battery capacity i.e. for a 120Ah battery choose a 15A charger.
The charge current should preferably not exceed 0,2C (20A for a 100Ah battery).The temperature of a battery will increase by more than 10°C if the charge current exceeds 0,2C. Therefore temperature compensation is required if the charge current exceeds 0,2C.
Deep Cycle AGM: - AGM batteries should be charged using a charger with a mode switch for AGM type batteries. It is recommended to use a charger, current limited to 20% or 0.2C of the batteries capacity at a charging voltage of between 14.6 – 14.8V following deep cycle use, or 13.6V – 13.8V for standby use. Charging should be paused if the battery or ambient temperature exceeds 50°C.
Deep Cycle Batteries: - Wet flooded deep cycle batteries should be recharged overnight at a rate equivalent to 10% of the battery capacity. State of charge should be regularly checked using a hydrometer or multimeter to ensure optimum battery condition is achieved.
Deep Cycle Gel: - Century Deep Cycle Gel batteries should be recharged using a charger recommended for Gel type batteries. The charging voltage is lower for Gel batteries and charging should be paused if the battery or ambient temperature exceeds 50°C. Charging using a vehicles alternator is not recommended as the current limit will be too high and can lead to over charging if not regularly checked. Use a charger, current limited to 0.2C (20% of battery capacity) at a charging voltage between 14.1-14.4Volts following cyclic use or 13.5- 13.8V following standby use.
So whats a C-Rate?
Charge and discharge rates of a battery are governed by C-rates. The capacity of a battery is commonly rated at 1C, meaning that a fully charged battery rated at 100Ah should provide 1A for 100 hours. The same battery discharging at 0.5C should provide 500mA for 200 hours, and at 2C it delivers 2A for 50 hours. Losses at fast discharges reduce the discharge time and these losses also affect charge times.
A C-rate of 1C is also known as a one-hour discharge; 0.5C or C/2 is a two-hour discharge and 0.2C or C/5 is a 5-hour discharge. Some high-performance batteries can be charged and discharged above 1C with moderate stress.
Things to note:
Most batterys only have 50% usable energy of the rated Ah, so that 50% of 110Ah is only 55Ah !!
If you needed 100Ah to run your camping kit, you would need 200Ah worth of AGM batterys.
A battery is classified as 100% full at >12.6V, and 50% @ 12.05V and flat <11.99V
Some data sources:
https://www.centurybatteries.com.au...alk/issue-2-battery-talk-battery-charging.pdf
http://web.mit.edu/evt/summary_battery_specifications.pdf
https://www.victronenergy.com/upload/documents/Datasheet-GEL-and-AGM-Batteries-EN.pdf
Charles-Augustin de Coulomb's C-Rate for Batteries
Video uploaded shortly . . . . . . . . . . .
edit:
my solution . . .
power, neg and quick disconnect for the starter battery . . . .
cover:
normal layout:
battery neg with NO CONNECTIONS:
my own fusebox, with incoming fuse and outgoing fuses. . . . which shows the Victron quick disconnect i use for direct battery charging.
the starter BM2 unit . . . . . didnt even realize that CTEK monitor was still fitted . . . though i binned it off ages ago lol . . . make sure everything is fused correctly
main battery connection . . . ( needs ferals and heat shrink - ill sort that soon )
and my earth link cable to body ground...
thats my solution.
EDIT: 2021 refresh
The 2021 line-up for EHU battery chargers is:
5A CTEK MSX 5.0 - 5A CTEK MSX 5.0
10A NOCO GENIUS10 - NOCO Introducing GENIUS10,
15A Victron IP65 BSC - Victron Energy Blue Smart IP65 Charger
30A Victron IP22 BSC - 30A Victron IP22 BSC
There is a third way... charge through the 13 pin trailer electrics. It works very satisfactory, is fairly weatherproof, Van is locked, doors and bonnet closed, and slides under the van easily out of sight.
You need:
136761 Raaco Storage Professional Solid 2 Transport Box
Raaco number 2 solid box £13
Tow electrics charger adapter - CTEK/Accumate/Optimate etc - DISCO3.CO.UK - Shop
13 pin CTEK adapter £24
https://www.amazon.co.uk/Masterplug-Extension-Lead-15-Frame/dp/B001T0HEUO?ref_=fsclp_pl_dp_4
15M masterplug fused orange extension lead £15
https://www.amazon.co.uk/CTEK-Start-40-106-Battery-Charger/dp/B00YBR8PFK
CTEK stop start charger £79 (Newer version of what I have pictured)
https://www.screwfix.com/p/2g-surface-box/89406
2 gang (double) surface mount box *make sure it’s the PVC twisty type not the shatter stiff plastic type* £2
https://www.screwfix.com/p/tower-male-comp-gland-white-20mm-pack-of-2/45943
2 20mm stuffing glands £2
https://www.screwfix.com/p/easydrive-electrical-screws-m3-5-x-50mm-50-pack/8036h
2 long 3.5mm machine screws (should only be a £1 have a look in your hardwear shop, but these things)
https://www.screwfix.com/c/sealants...a#category=cat850058&brand=sika&sort_by=price
Sikaflex (not mastic, it let’s go of its grip eventually, gripfill has no flex either). £7
And a random piece of wood. Total cost (have a google, don’t forget delivery costs) a not inconceivable £150ish. I also spent £5 on a nice engraved plastic label from the key cutters with “BATTERY CHARGER” too. So £££ ouch...
How to?
Cut a 20mm hole in the side of the Raaco case, the hack saw from the lid down to meet the hole, file the rough edges.
Flip white plastic box upside down, place on wood base (wood ideally overlapping white box by 20mm all round) poke sharp thing/terminal screwdriver through screw holes to mark wood. Drill wood where marks are with 3.5/4 mm drill. Trial fit wood to white box with 3.5 electrical screws. Disassemble again!
The white plastic box has two 20 mm holes cut in one (narrow) end, stuffing glands are fitted, then it is bonded with sikaflex to the middle of the box and left over night to cure. (It’s under the wood the charger is screwed to in my picture).
Next day remove the CTEK 13a plug and orange extension lead socket from their espective leads. Then feed each lead through stuffing gland, tighten stuffing gland so it grips the cable, then hard wire (with a connector block or similar) the charger plug to the socket of the extension lead. (This way you can stick a plug back on the CTEK should you ever upgrade or return for warranty etc).
Screw wood to white box again, being careful not crush cables. Next screw CTEK to wood (with screws NO LONGER than the wood thickness!) and wrap orange cable round white box. Plug trailer adaptor into CTEK plug. Shut blue case lid and your done!
New Victron Charger added to the collection . . . .
i had lower amp chargers (5A - 15A) about for the SLA & AGM`s i had over the years. . . . .
But with the Lithium's, and having two of them I've added a 30A Victron 12/30/1 to my collection.
Victron Energy Blue Smart IP22 Charger 12/30(1) 230V - Blue Smart IP22 Charger - Victron Energy
Victron Energy Blue Smart IP22 Charger 12/30(1) 230V - BPC123042002: Amazon.co.uk: Car & Motorbike
you can see that charger and the Lifepo4 in action here > Lithium Lifepo4 12v Batteries - - - Time For An Upgrade ? - - -
Reactions: mmi
I have an Optimate charger I used to use of my motorbike SV650. It's only 0.6Amps but has a desulphate mode. That's what I have been using - it took 3 days to charge the battery on my T6. But now - it's discharged again. I have a Noco device but not used it yet. I've not even looked at it - I thought it was just a mobile jump starter.
YOU NEED TO FULLY CHARGE THAT GB70 BEFORE USING IT !!!!
so plug it in now and get it charged
Yep. They are great jump packs..
You just need to get a decent
Smart charger for the Van and leave that Optima thing for the bike. =)
Victron Energy has added History Monitoring to it APP for the Blue Smart range of chargers . . .
Just look how happy she look is . . . =]
i have the Victron Blue Smart 12/30 and the Victron Smart 12/15, both are excellent chargers with a great APP.
This feature just make the APP even more usefull, especially for those of you that have then as part of you EHU charging.
heres my 12/30
Screenshot_20200522-065304.jpgScreenshot_20200522-065446.jpgScreenshot_20200522-065450.jpgScreenshot_20200522-065509.jpg
Time for an upgrade on your charger . . . ?
Have a look at the range:
Votronic Standby Trickle charger :
Hoping to install my leisure battery set up next week; 110 ah AGM battery, CTEK DC-DC charger, will probably get a BM2 monitor, and further down the line add some kind of solar panel to keep the leisure battery topped up (I use the van most days so it should stay charged from the alternator). Most of my camping is on EHU, the leisure battery will run interior ceiling LED lights and usb points. The 240v EHU for cool box, kettle etc. I would like to add a battery charger under the seat next to the battery on a dedicated EHU socket. Having just sold my motorbike I have the following charger; Optimate 4 going spare. Would this be any good to keep a trickle charge going in or am I wasting my time as it seems to put in just 0.8 amps, ta Jim
No I wouldn't bother.
0.8A is way to lower amperage.
Look at getting a 3/5A or up EHU charger.
Can one of the gurus help out with regard to the Victron chargers please, the 12 30 (1) and the IP65 12 15.
I’ve got a Lifos 105 ah battery that states the recommended charge current is 20-50 amps.
So all good with the the 12 30 (1).
But the IP 12 15 data sheet states that it’s recommended for batteries of 50 - 150ah.
So that should work ok too?
Which charger should I be using, pros & conns
My preference is the IP65 12 15 as I’m trying to use Deaky‘s under bonnet set up.
Cheers,
flo
You can use either..
The 12/30 will charge twice as fast tho.....
