IMO 235/60/17 size, fill the arches by an extra 11mm all round; 11mm more ground clearance; slight increase in gearing. Just look so much better than stock imo.
To get the maximum utility out of your T6, I think the best 2 options are:
Both tyres have: deep tread; good voids Mud and Snow rating; tuff; 3PMSN winter rating; good wet grip; reasonably quiet
Michelin Agilis CrossClimate 235/60 R17C 117/115R - mytyres.co.uk
Nokian Tyres / All Season SUV 4x4 / Nokian Weatherproof SUV - 235/60 R17 106H XL TL Fuel Eff.: C Wet Grip: A NoiseClass: 1 Noise: 69dB All Season - Four Season - All Weather - SUV/4x4 Tyres - 17" R17" - 235/60/17, 235/60R17
High abilities in all conditions; on road; off road; winter; summer; deep standing water etc etc. Run them both all year round, particularly in the UK, where summers aren't to hot, for too long
Look Great
Will last 40k+ miles and still have 3mm tread left
Michelin are more expensive, are now fitted as standard to many NHS ambulances as all-seasons; have very high load ratings, so very tuff, but may be a stiffer ride; look really beefy; Michelin is probably the most respected tyre manufacturer in the world.
Nokian are cheaper; great reviews; I've run them for 40K miles, they are brilliant; very grippy off-road; brilliant in snow- better than some full winters
Just picked up some new Amarok 'Cantera' wheels
wondering if I definitely need the 255/45/19 spec tyre( with a dsg, t32 4m weight)
over 245/45/19 say. I think these look and fit better as rim is an 8J)
and are better suited to original 215/60/17 in terms of Speedo.
102 =850kg
104=900kg load rating
102 =850kg
My cantara alloys have 245/45/19s and I personally think they look just right. The tyre wall is inline with the rim
102 =850kg
Make sure you get the load rating for the t32 ....103 and above but you’ll probably only find them in 255 45 19 /104 from nexen
I can’t find what size the rear spacers should be to bring the Amarok wheels 19, in line with the front I think it was 15mm but can’t find the post any ideas ? And do I need hubcentric one ?
15mm according to the posts I’ve read. I’m moving my fronts (15mm) to the rear when I swap mine over.
The Amarok wheels stick out about 10mm more than the T6 ones (10mm less ET Off-set),
so you need 10mm less spacer than you would with the same width tyre on a T6 wheel.
I'm running 235 tyres on a Amrok wheels; for me the max spacers would be 25mm on each rear; 10mm on each front.
100% yes to hub-centric spacers; TUV approved is well worth considering also.
