Hi Fintank, I had them powder coated by South West Wheel Repairs in Exeter, they did a cracking job. I don’t know the exact name of the colour. When I took the wheels in I knew I wanted bronze, he showed me a couple of options and that’s how they turned out.Mate these look class. Did you paint these yourself? If so which paint/colour did you use?
BFG AT KO2 225/65/17 would be as large as I would personally go, not due to width as 255's are fine width wise, its the diameter/rolling radius that starts to become more problematic.
the 225/65/17 are 4.8% larger than standard sizes.
So the gearing is upped by 4.8%; the wheel is 33mm larger in diameter; which is 16mm radius, so the van sits 16mm higher; the wheel arch gap is closed 16mm all the way around.
You can go upto about 7.5% larger, but the drivability of the van will start to suffer in terms of gear changing positions; acceleration etc etc.
Also with the larger tyre, you may not want to drop the van by more than 30mm, if you choose to drop it at all.
You may not need wheel spacer with the 225/65/17, but if you go larger you will need them because it will catch the inner plastic arch liner on full lock, or during larger suspension compressions.
For me it is 225/65/17 in the sizes available for BFG AT KO2's
Hi - I’m new to owning a T6 and currently deciding to change over stock tyres and wheels to modular steels with AT tyres. My concern is ride height, and as you’ve mentioned here the bigger tyres and 17” wheels clearly raise the overall ride height.
Im currently debating whether to go for 16 wheels with 235/70/16 tyres or 17 wheels with 235/65/17 tyres.
Do you know which out of these two options will keep the ride height increase minimal? It feels like a catch 22 as one tyre is bigger, and the other the wheel bigger.
Thank you - very helpful![]()
Alloy Wheel & Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
Alloy Wheel & tyre fitment calculator - it calculates inset, poke, speedo error, tyre stretch and loads more.www.willtheyfit.com
I've lost about 4mpg with my K02's. Over 100 miles that's about £3.Hi - I’m new to owning a T6 and currently deciding to change over stock tyres and wheels to modular steels with AT tyres. My concern is ride height, and as you’ve mentioned here the bigger tyres and 17” wheels clearly raise the overall ride height.
Who is they? I'd love to get 50K from a tyre. My van's on 54K miles and on it's third front tyres as far as I know (though the guy I bought from was running bigger wheels for at least 6K), so 25K miles at the most (GoodYear Marathon)Over the life of the tyre, say 50'000 (so they say)
www.google.com
There is a place near me that does it in a day. Im sure there must be ones near you that do the same.Ŵould love the look shown in Arrows pictures. Been thinking about it for ages! My only hesitation relates to mpg and road noise.
question: I only have the wheels/tyres that are on my van so how long would it take to get them powdercoated and refit?
This isn't really about the tyres though? For peace of mind the garage needs to be telling you why the wheel came off?Would love some advice please. I took off my standard tyres (215/60r17) and put on BFG 225/65r17 and had the wheels powder coated. When I dropped the wheels off to be powder coated the garage put substitute wheels on. I drove a mile away and a wheel came off. Fortunately I was travelling very slowly. The garage came right out put the wheel back on and my car went into another garage who replaced wheel bearing and hub assembly, brakes & discs and had tracking done. The wheel coming off really shook me up and I am so nervous about my tyre set up now as I changed them based on information I found on this thread and no professional has looked at my van and said that is ok. I know it is unreasonable but I am worried all the time I am driving now. I would be grateful for reassurance that putting the larger tyres on the wheels that are meant for 215 is ok and nothing is going to fall off. Also, the garage replaced the locking wheel nut - are we meant to have special locking wheel nuts on vans because these seem to be regular locking wheel nuts. Thank you very much. I've lost it. I'm worried about everything now. Vans looking good though.
Wheel place couldn't explain - they used my wheel nuts. The only obvious explanation is they weren't done up. They paid cash for work done and haven't supplied receipts just written confirmation. Thinking for peace of mind I should go to another garage to check everything out and for reassurance re tyres & wheels but if tyres are different to the ones on door label will they say ok? Wondering what sort of specialist I should look for.This isn't really about the tyres though? For peace of mind the garage needs to be telling you why the wheel came off?
Or the second garage can give your van a once over - sounds like they have and reassure you that way?
Great to hear you've done 30,000 on same tyres & wheels. Thanks for letting me know.Yeah it isn’t a tire issue, I’ve got the same tires and powder coated rims, did a 30,000km on road and off road trip around Australia without a issue.
the garage has stuffed up, and the rims weren’t fitted properly, it’s possible they forgot to tighten the nuts.
im sure they will double check this time, but I’d stick to a tire shop from now on, for a wheel alignment and rotation
Right, lets look at facts and probabilities; (correct me if I'm wrong)When I dropped the wheels off to be powder coated the garage put substitute wheels on. I drove a mile away and a wheel came off. Fortunately I was travelling very slowly.
