What controllers are required?
I recognise that picture ! Hoping to get them fitted soon
Click pauly's name under his picture on the left and where it says start a conversation click that. That is the PM system.@Pauly I’ll try and work out how to PM you and be in touch! I’m so rubbish with computers lol
Kufatec kit description says: "Complete kit closing aid tailgate for VW T6 SG " does this mean this is not valid for any T6 tailgate? How to check if mine is an SG?Is this what you are referring to?
Ebay kit ---> For VW T6 Multivan Bus etc. Genuine Kufatec Complete Set Latching System | eBay
Kufatec kit --->KUFATEC
Kufatec loom ---->KUFATEC
If you buy directly from Kufatec you can give them your UK VAT number and save 19% on German VAT.
I have this problem too. Did you resolve it?So I've fitted this on the sliding door of my '18 plate T6 Highline. The latching itself works fine, but the problem is the dash indication of door opening; it always shows open when the door is closed and vice versa. Have tried two control modules - 7H0 959 243 D and 7H0 959 243 H -and the same problem occurs with both. Measuring the output wire from the power latching module to the BCM, it's connected to ground when the door is open - the reverse of what you'd expect!
Has anyone seen anything like this? Is there something in VCDS which codes this behaviour?
