Kenwood DNX5180dab installed with the following-
Flush fit facia
Interface for parking sensors, MFSW and MFD
USB retention kit, so you can still use the dash USB socket
Dab adapter
Fm adapter
Our Services-
Carpet/Vinyl Lining
Full electricsinc solar
Window installation
Webasto heaters
B14 and Vanslam suspension
Pendle Performance Agent
Kombie conversions
Cruise control
Audio inc Plug and Play headunits and speakers
The home of the original underseat sub enclosures for T4,5 and 6
Www.Absolut5.co.uk
01980 624740
I had a kenwood fitted at the main dealer lat week but it was 1.5 hours from me. When he put the head unit in it wouldn’t power up and he realised they had sent the incorrect connection block. I’m not travelling back to have it fitted do I told them to send it to me and I will fit it as it’s just plug and play. My question is will the nav display directions on the dash ie, between the clocks as on one of your pictures. My van is a camper but was a highline van. Last of all is they anything else I will miss out on by doing it myself. Thanks
Sounds like they had a T5 harness and not a T6 one
Unless it had a nav unit in there already then it won’t display the directions on the mfd until it’s coded
What dab aerial did they use ? Most dealers stick a glass mount aerial on, and nearly all T6s have the aerial in the mirror, so just requires a adapter
The usb on the dash won’t work, this need a retention kit
All stuff we can supply
Yes it’s the one on the windscreen.
I didn’t have sat nav befor so can they coded it to work if I go back there for them to fit?. Yes I think it is the T5 as there was no live pin to match up to live on the head unit. I was curious about the Ariel as I had dab before so assumed I already had a DAB aerial fitted. Cheers
Yes the dab aerial is in the drivers mirror, so it just needs a adapter. Also the usb needs a kit to retain it
Vw don’t tend to alter the coding over what the factory sets, so may not do it. But ask them
Can you pm me a price for the aerial adaptation and is that just a case of plug and play?. Thanks
Another if our very popular Signature audio setups installed into a very nice T6 today,
We only use the very best audio products in any of our installs to give the best performance
The following was installed in a new T6 sportline
Hertz Mille Legend door speakers
Hertz Mille Legend tweeters
Hertz Mille Legend sub in out underseat enclosure
JL Audio VX1000/1i mono amp
JL Audio VX800/8i 8 channel amp
Audio control LC7i to deal with speaker level in and compensate for the bass roll off on factory headunits
All wired fully active
Dynamat was used through out and ply wooden collars machines to allow the larger then normal Legend speakers
Foam fast rings and connection cable was used through out
It’s been a mad couple weeks of Audio installs with plenty more to come.
From just a basic speaker upgrade from Blam and the new set on the market from Eton for the T5 which uses a 8” door woofers and a midrange and tweeter for the dash.
Headunits from the Kenwood DMX and DNX range to the Massive Alpine Halo
We can retain the factory parking sensors, MFSW and even the MFD sat nav directions with the Kenwood DNX range
Our signature systems have been massively popular using Hertz and JL Audio products featuring our designed and manufactured underseat sub enclosure
Hertz Legend speakers are gaining popularity too.
Call or Pm us for your Audio requirements
Our Services-
Carpet/Vinyl lining
Full electrics
Window installation
Webasto heaters
Kombie conversions
Cruise control
Audio inc plug and play headunits and speakers
The home of the original underseat sub enclosure for the T4,5 and 6
Www.Absolut5.co.uk
01980 624740
FD372EF1-EB91-409C-940B-2FC267AC0EB3.webp CD1A1BAA-7F4E-4ED7-93D7-196EF4364DD3.webp BC4BF45F-7567-4A78-8739-613E299F3158.webp 38C3C8BE-B145-4575-822B-6E8915AF4FC8.webp 14386B1F-CEBA-45BF-BD3F-BA804C40DA8F.webp 6EC6195A-2FBC-4216-B32E-9A1D3C8BB078.webp 3C7EF81E-3B80-458B-B4EC-E959AF525A1D.webp E663BB8D-A885-4B87-B1EE-6822B30FFC0A.webp DB50DE5D-37C1-4BFB-92E7-898219A19160.webp 21065E61-736D-4171-AB24-547236F68369.webp 95A35AFB-FF8A-4EB6-B5DC-C149B3C7247C.webp A59D7469-1DE0-40C9-866A-6A21361671ED.webp 390455BF-1A98-4EB2-B476-699DC47327AE.webp F66204E7-A500-4F54-A84F-D6ABC885078C.webp
We had this California owner drive 5 hours for us to sort his Audio
He had been to 2 very well known companies before, the first installed Alpine speakers and a underseat woofer.
He then went to the other and was talked into upgrading the dash tweeters to Focal and a Audison Bit 10..
We listened to this for the first time with the customer and came to the same conclusion, that it sounded worse than Stock factory speakers.
We then went about stripping it down and it was worse than expected, with messy cabling just tucked under the carpet, sound deadening done to a low quality level which peeled off very easily
He settled on our very popular signature audio setup using Hertz and JL Audio product based around our own design and manufactured underseat sub enclosure
The owner had biggest smile when he left but regrets it took 3 attempts to get it right..
Some before and after pictures-
Pm or call us on 01980 624740 for all your Audio requirements
Www.Absolut5.co.uk
D1BDCE87-EC61-4458-AE02-5A642D56D47E.webp F97B6BA1-753D-4BF5-98AF-B255F93AD886.webp BEA330DA-59A0-415B-9591-7CFCF03C3E32.webp 4874206F-ABA3-46F2-940F-40F9837434C8.webp AF954F2F-7AD7-4B7C-9F1B-1FDCEF2C392F.webp 9ED46AF3-25E3-4EDC-946C-A079FF5A02BA.webp 2CCC31F3-1624-4C5B-82E3-D8DC7F9D5006.webp A88A7054-B0B4-4064-9C5A-4E4A3BB7E863.webp FEB7968E-88BD-4583-8271-4FEE40EF54DF.webp
Www.Absolut5.co.uk
View attachment 41307 View attachment 41308 View attachment 41309 View attachment 41310 View attachment 41311 View attachment 41312 View attachment 41313 View attachment 41314 View attachment 41315
Is the Bit 10 for sale? A friend of mine has one in his Merc and the sound is absolutely amazing now!
This Transporter left us this week. With a audio upgrade consisting of some eye watering equipment
Alpine Halo
Audison Voce AV Uno mono amp
Audison Voce AV quattro 4vchannel
Audison bit10D
Swapped out the input boards on the amps for the AV bit IN HD for a digital connection with the Audison bit 10D
Hertz Mille Legend ML 280.3 tweeters and Mille Legend ML700.3 mounted in custom pillar builds
Hertz Mille Legend ML 1650.3 running active in the doors mounted on ply collars, a good amount of Dynamat and foam Fast Rings
All set using Audison bit tune
Our Services-
Carpet/Vinyl lining
Full electrics
Window installation
Webasto heaters
Kombie conversions
Cruise control
Www.Absolut5.co.uk
01980 624740
A1C16530-2B51-46E5-BDBD-30D9D963AB16.webp 07520AF5-8AA9-4755-9CDB-D2CA2C50E827.webp F5E66CE9-6F49-4FCF-89F2-9C5F5B3E8B53.webp F1E543C2-FBDC-48EB-995C-56B34B5EC58C.webp 66C80730-0409-44AA-B55B-741488D061DC.webp 85EC76B4-ED7F-433F-BA64-A8BEF7490E1B.webp 2E787A12-DDEA-4366-BEFD-2748572C0804.webp
Another Signatute Audio installed this week using the basic Composition colour head unit
This setup consists of -
hertz Mille pro front components mounted on wooden collars and a good coverage of Skinz sound deadening to the door skins and door plastics, replacing the pillar tweeters
JL Audio 10w1 10” sub in our own design and manufactured underseat sub enclosure for the twin passenger seat
JL Audio XD500/3. 3cahnnel amp to drive the Hertz and sub
JL XD bass control mounted in a dash blank
And lastly a set of basic 2 way coax speakers mounted in the rear
This setup is very basic and quite economical but leaves owners stunmed with the quality of sound and the bass response
Our Services-
Carpet/Vinyl lining
Full electrics
Window installation
Webasto heaters
Kombie conversions
Cruise control
The home of the original underseat sub enclosure for the T4,5 and 6 NOW available as a active setup
Www.Absolut5.co.uk
01980 624740
Hey @Absolut5
I have a Kenwood DMX7017DAB in my T5. Just put a deposit down on an '18 Highline T6. Is it possible to retain the parking sensors and MFSW functionality if simply swapped out the head unit?
Hey @Absolut5
The only way is to use a Connects2 infoadapter, which plays the parking graphics through the reverse camera port
You will also need a dab aerial adapter and a usb retention kit if you want the dash one to still work, oh a fm adapter but the T5 one may be correct if it’s a twin one
