Mine is from Evo DesignWhere do you buy kits from and is there different ones?
Thanks mate ill check them out , not sure if i want cooking facitltys in my van , i wouldnt mind them at back of the van in like a pull out shelf under rib ..not sure if you can buy them like that or have to make your own for sink and hob?Mine is from Evo Design
In that case check out slidepods mateThanks mate ill check them out , not sure if i want cooking facitltys in my van , i wouldnt mind them at back of the van in like a pull out shelf under rib ..not sure if you can buy them like that or have to make your own for sink and hob?
Thanks for the comment mate. The hidden clips basically go into the hole in the plywood. You then carpet over them on the outside and are left with just the clip on the rear that jams in the hole.Absolutley tremendous effort @xpfloyd I've just bought my sound deadning gear etc so my build starts now, few things im unsure about, how do the hidden clips work how do they attach to the ply?do they go in holes tgen get carpeted over? Also does rib just get screwed to floor.? That cant be safe, how do you know where it can be attached , also did you read al, the treads on here to do all electrics yourself etc? Im qute handy so im doing most of it myself but the electrics are something I've no idea about really .
As @xpfloyd says, sounds like a slidepod style thing. Be worth dropping @andythom188 a PM as he may still be thinking of selling his slidepod.Thanks mate ill check them out , not sure if i want cooking facitltys in my van , i wouldnt mind them at back of the van in like a pull out shelf under rib ..not sure if you can buy them like that or have to make your own for sink and hob?
Brilliant cheers daveyAs @xpfloyd says, sounds like a slidepod style thing. Be worth dropping @andythom188 a PM as he may still be thinking of selling his slidepod.
Ahh superb , slidepods is that what they are called ..yeah im defo up for that ,is there ,a thread on here where it lists the order of build in numbers etc like no 1 , strip van and sound deaden , 2 etc,3 etc? Just so we know in which order to do things?Thanks for the comment mate. The hidden clips basically go into the hole in the plywood. You then carpet over them on the outside and are left with just the clip on the rear that jams in the hole.
For the Rib I used a kiravans installation kit which is essentially a steel beam that bolts to the chassis below the floor and then the seat bolts to the beam. That’s the only way to make it crash tested. Bolting direct to the floor is an option but means you can never allow anyone to use the seat whilst travelling, even then the seat could probably dislodge in a crash.
For the electrics I basically asked stupid questions on here, used google and asked travelvolts questions (which is where I bought most bits) and stumbled through it. It all works as it should though and I learned a lot in the process
Not really. I just picked it up from reading other peoples build threads. I basically went - strip - windows - pop top - sound proofing - carpet lining - electrics - insulation - panels - floor - furniture - finishesAhh superb , slidepods is that what they are called ..yeah im defo up for that ,is there ,a thread on here where it lists the order of build in numbers etc like no 1 , strip van and sound deaden , 2 etc,3 etc? Just so we know in which order to do things?
VWT6-4.jpg by VW T6, on Flickr
VWT6-2.jpg by VW T6, on Flickr
VWT6-3.jpg by VW T6, on Flickr
VWT6.jpg by VW T6, on FlickrYes mate no issues. Removed the bumper internals from my start line and added it to the high line and it bolted straight on. Had to buy a grille and inserts to finish it off@xpfloyd i saw you bought the highline bumper from off here - did it all fit ok? im trying to source parts but the variations of all the part number are a little offputting..
