Then you're possibly in luck.2011. With climatronic![]()
Here's the guide:
I would like to fit only the remote,What are you looking to achieve. Fitting the remote only or remote and screen?
Did you find a copy of the full t6.1 wiring diagram yet?
Thank you, my t6.1 is 2021,I found some wiring diagrams yesterday on cardiag.com (couldnt save it and after zooming was to bad for screen capture, website was running fine and today couldnt open diagram, trying the same tomorrow)To explain
You are trying to instal the remote module r64. It has 5 connections.
The 2 connectors T2tj are the aerial. This should be part of the door wiring loom on a car with the option from factory. I doubt it’s in your door but a universal aerial with farak connector works.
T6af pin 2 is the signal wire which connects onto the heater connector t6aw pin 2 and remotely activates the heater. As said this wire might be there and can be found under the left car seat on red plug.
T6af pin 1 and 6 are the power and earth for the module. Plenty of options for those under the left car seat. There’s an earth point on the chassis under the carpet and you can use a fuse tap for power.
Hope that helps get you started.
My screen captures were from the general flow chart for t6.1. I show downloading it in my video, costs 8 euro and then you can use pdf search function to find stuffvideo om
Where can i find the video? Someday next week i will be less busy, so i will take a closer look on wiring and heater it self. Is there a way/website to check if the remote controle (telestart 3Q0963513) unit is for my car? Or is it for every kind of transporter.My screen captures were from the general flow chart for t6.1. I show downloading it in my video, costs 8 euro and then you can use pdf search function to find stuff.
Difference between T6 and T6.1 is the additional roof display and it's wiring which becomes not only more complex but also much more expensive because roof units are 150+ EUR. For T6 the roof unit is not mandatory and installation can be carried out by the novice. For T6.1 - not really.in that thread he says it gets complex to install the control display and the coding has to be done with Odis engineering. for just the remote module it’s not that different.
Someone also chimed in and said that on their 22 car the wire from heater to seat was missing.
Correct me if I summarised that incorrect. My German’s ok but not perfect and German forum boards are full of slang and shorthand that I struggle with. Hence why I hang out here. (-;
Well, I gues you know better than those who do it for living. And 20 pages on TX board discussing exactly this topic on T6.1 is also a myth.Thanks for clearing that up with some t6.1 knowledge.
As I remember Setting it up without the roof display was one option which I could have coded with Odis so “special patch” might be a myth.
Don't want to start an argument, I'll probably need your help to activate the Air standing heater. Did you ever finish the video on that topic?
Regarding experience, I rewired my last BMW from one electric architecture to to the next gen and I am automotive design engineer by trade so not totally clueless.
When someone says they have a special tool or patch and they're the only one who can make it work. I get really suspicious.
I'd love to test the theory on my neighbors T6.1 but I don't think they would take too kindly to me connecting it up to Odis to see if the option to install without screen is there and you can bet if i do they will hang every future problem at my door.
Glad you liked my trump Joke.
Although expensive this kit is available for t6.1 to take the guess work out of fitting a remote and you can specify plug and play.
Zuheizeraufrüstung VW T6.1
Rüsten Sie den Zuheizer Ihres VW-T6.1 einfach zur Standheizung auf. Passend für folgende Fahrzeuge mit kraftstoffbetriebenen Zuheizer: VW…www.danhag.de
warm regards Andrew
