No, it’s the aircon on drain, there isn’t a D+ from the alternator either
there is a grommet in the plenum chamber behind the battery and if you need something similar to D+ then you can use the 2nnd battery relay isolator signal from the BCM
I suggest using any of the empty ports towards the top of the centre column. It is important to have the piggy back cable exiting towards the passenger side otherwise you have no fuse protection.
You are not alone!many thanks...i wash in a rush to use van....had all carpets and seats out...put all my wires and my 240 hook up wires through the top left bulkhead grommet...(i have hook up under bonnet)...rebuilt everything...
guess who forgot the switched live....lol...what a tool.... nmind...
