So, got Solar panels install as part of our conversion, now completed and the panels are wired to the MPPT through to battery setup etc, feeding Leisure Battery and through some other wizardry it also tops up the Van main battery etc.
I have just got myself one of those Power Generators/Solar Generators from ECOFLOW, using the cable that connects the EcoFlow for the Solar Panels I plugged this into the MPPT trying to see if I can use the Dual Battery function to still charge the Leisure battery and have the 2nd feed going to the EcoFlow. It seems as if the MPPT did not like it and reported a fault with Battery 2 (the ecoflow) which I sort of understand as there would be no feedback from the Ecoflow to say its charged etc.
SO having a think about this, and this is my question, could I split the Source leads from the Solar Panel to feed both the MPPT as now, plus the the split feed direct to the Ecoflow using the Solar Panel cable.
Things I do know:
1. The Ecoflow will only draw power to itself when it is in use or below charge, stops input if at 100%
2. The MPPT will still get the same feed from the Solar Panel
3. I am aware that this will reduce the input Amps as it will in effect be providing power to 2 units not 1
Your thoughts on this idea are appreciated, I am ok with wiring and electricals just unsure on whats the best was forward here... also if anyone has done this and made a better job please also let me know
Steven
Things I do know:
Steven
