The wire is now connected to pin 1 on the webasto, and embeded with the original wire loom. A stealthy install.. Nope! Not even close.. lol
A 8mm spanner / wrench, for the removal of plastic cover underneath the car
A 13mm spanner / wrench to the adblue tank
pliers to remove those pesky rusty push on nuts on the plastic cover.
I must say, been on the back for an hour or 3 in gravel, doin this job was not fun at all.
So if i have wraped my head round this correctly, If i connect this wire that i have just pulled to one side of a relay and the other side to ground, the faultcode for heater blower should not be present anymore?
So now I need to sniff out where this T17a connector is hiding behind the glove box. Do you have a picture of that connector location?
If that pin 1 on T17a gets 12v from somewhere else, the fan should run at any set speed on the dail if my thoughts are correct. I want to give this a try..
Not sure if there is a main blowerfan relay or how that is connected, if its a relay then its for sure monitored and injecting a voltage on it might upset the vehicle with faultcodes and other "fun" issues
