SW:7E0-963-272- B HW:7E0-963-273- A --- Additional heater
Component:STH-T5GP2 003 0009, Encoding:5101
EV_AuxilParkiHeateWOST5G2,001013,EV_AuxilParkiHeateWOST5G2.rod
Monday, November 24th,2025,13:26:38:00009
VCDS Version: RUS 22.3.1 Version data: 20220520 DS338.0
VCID: 2B55B2AB420539D748-807E
IDE00470-First fuel filling,Yes ,1
IDE06640-MAS01167-Fuel booster pump-Operating time,20 s,5
IDE06640-MAS05078-Fuel booster pump-Minimum fuel level in the tank,0 l,5
IDE06640-MAS05079-Fuel booster pump-Pre-fuel quantity,200 ml,5
IDE06640-MAS05080-Fuel booster pump-Maximum parking time,0.0 H,5
IDE06640-MAS05689-Fuel booster pump-Control signal delay,10 s,5
IDE06642-MAS05071-COOLANT switch valve-Temperature difference engine/autonomous heater,5 °C,4
IDE06642-MAS05072-COOLANT switching valve-Maximum engine speed,2500/min,4
IDE06642-MAS05073-COOLANT switch valve-Residual heat: threshold,55 °C,4
IDE06642-MAS05074-COOLANT switch valve-Take into account the engine speed,No ,4
IDE06686-Threshold value of voltage drop,11.3 V,1
IDE06687-CO2 adjustment,177 ,1
IDE06688-Activation of the additional heating mode,active. ,1
IDE06689-Minim recognition. Permissible voltage: time threshold,20.0 s,1
temperature threshold: ambient temperature,12.0 °C,11
IDE06690-MAS05062-Control parameters in the additional heating mode-Lower temperature threshold: coolant temperature according to CAN,72 °C,11
IDE06690-MAS05063-Control parameters in the additional heating mode-Upper temperature threshold: coolant temperature according to CAN,88 °C,11
IDE06690-MAS05064-Control parameters in the additional heating mode-Lower temp. the threshold for dir. Partial heating after dir. Full heat,75 °C,11
IDE06690-MAS05065-Control parameters in the additional heating mode-Lower temp. threshold for starting from the Stop mode,76 °C,11
IDE06690-MAS05066-Control parameters in the additional heating mode-Upper temp.the threshold for dir. Full heat after dir. Partial heat,80 °C,11
IDE06690-MAS05067-Control parameters in the additional heating mode-Upper temperature threshold for the Stop mode,86 °C,11
IDE06690-MAS05068-Control parameters in the additional heating mode-Temperature threshold for operation in the regulated mode,78 °C,11
IDE06691-MAS05064-Control parameters in the autonomous heating mode-Lower temp. the threshold for dir. Partial heating after dir. Full heat,60 °C,7
IDE06691-MAS05065-Control parameters in autonomous heating mode-Lower temp. threshold for starting from the Stop mode,64 °C,7
IDE06691-MAS05066-Control parameters in the autonomous heating mode-Upper temp.the threshold for dir. Full heat after dir. Partial heat,80 °C,7
IDE06691-MAS05067-Control parameters in autonomous heating mode-Upper temperature threshold for Stop mode,86 °C,7
IDE06691-MAS05068-Control parameters in autonomous heating mode-Temperature threshold for controlled operation,80 °C,7
IDE06691-MAS05069-Control parameters in autonomous heating mode-Temperature threshold to activate the supply air fan,99 °C,7
IDE06691-MAS05070-Control parameters in the autonomous heating mode-Control algorithm,Steplessly ,7
IDE06692-Take into account the requirement to enable additional heater from klim. Settings,Do not ignore ,1
IDE06693-CAN air pressure rating,Yes ,1
IDE06694-MAS05076-Minimum gorenje duration-Time,160 s,2
IDE06694-MAS05077-Minimum gorenje duration-Deviation of temperature thresholds,1 °C,2
IDE07160-MAS04357-Shutdown of the control unit: shutdown time-1,140 min time,2
IDE07160-MAS04358-Power off: Power off time is 2.20 min,2
IDE11873-MAS13407-Advanced pump control-Outdoor temperature: lower limit,15.0 °C,4
IDE11873-MAS13408-Advanced pump control-Outdoor temperature: upper limit,17.0 °C,4
IDE11873-MAS13409-Advanced pump control-Engine temperature: lower limit,35 °C,4
IDE11873-MAS13410-Advanced pump control-Engine temperature: upper limit,30 °C,4
MAS01488-Circulation pump,12750/min,1
MAS05075-Ethanol content treatment,No ,1
MAS09096-Circulation pump: lock,2 ,1
ENG119729-activacion_of_simulated_flamme_run_for_emv_measuring,No ,1
ENG119721-development_data_on_CAN,inactive ,1
