I'm pretty sure the DRL should be on all the time, even with switch on 0.main light switch from 0 position to SIDE LIGHTS position is good
0 no drl , side light small light (5.5v)
and engine is running my voltages at PIN 12 13.5v and PIN 10 should be 5.5v
Can I ask what the “ALWR” is please?the 4 wires b56,b5,b28,b6 it is marked above go to the bcm white pin
b56 pin 56
b5 in 5
b28 in 28
b6 in 6
and the 2 cables to the 30A fuse of the alwr
Yes that’s it. Coding module looks a good idea but I’d imagine there’s cheaper options.I've vcds and a log from a van with factory led, working though this post there pretty much all the info we needThis is the kit?![]()
KUFATEC Adapter LED-Scheinwerfer for VW T6 SG
Adapter for retrofitting LED headlights for VW T6 SGkufatec.com
Looks good, I’m hovering over buying this. I see they even have a plug in module to take care of the coding.
Abbreviations are of german words/phrases so the letters often dont make senseCan I ask what the “ALWR” is please?
Ok. Is this normally fitted when halogen lights are installed? Or do I need to buy this module also?Abbreviations are of german words/phrases so the letters often dont make sense
ALWR is the auto levelling/range control setup
I’ve seen them cheaper for sure.Amazing work guys, thanks for the guide and info.
JuI'm just looking into buying the headlights for the upgrade from my H4s. Looking on ebay etc, it would seem they are going for £800 approx per side. Is this the going rate would you say guys? Also can these still be purchased new from VW or will this be difficult with the T6 now discontinued to make room for the 6.1?
Have you got the levelling parts too?I got mine from t6 Cotswold parts . Along with the kufatec wiring. I’ve yet to install them
No. Going to try without firstHave you got the levelling parts too?
