Yes that is correct.Problem fixed by changing byte 16 to D0
Well done!
Your Byte 16 originally had all possible PWM (pulse width modulation) for front lights switched ON ( bits 0 - 3 ).
By modifying the value of Byte 16 from ?F to ?0 you have effectively deactivated this feature completely.
PWM switched ON( particularly bit 0 - low beam, bit 2 - DRL & bit 3 - high beam) won't allow OEM LEDs to operate properly.
