And by the way, all of the wiring from the halogen setup(either H4 or twin H7) can be reused for the LED lights except for the side lights.
Two new wires have to be run from BCM plug B
PIN5 to LHS lamp PIN10
PIN6 to RHS lamp PIN10
The reason is below.
This is the voltage produced by BCM to the LED headlamps on PIN10 when side lights are switched ON.
At the same time 12V DC is supplied to PIN12.
And when DRLs are switched ON both PIN10 & PIN12 receive 12V DC.
If there is only one PIN(either 10 or 12) supplied with 12V DC DRLs/sides will remain OFF. Obviously this should not happen when retrofit was carried out properly.
I forgot that my retrofit was from twin H7 to LED and I didn't take in consideration upgrade from H4.
So complete VCDS coding for LED upgrade/retrofit from either H4 or twin H7 should be as follows
Byte 18 bit 0 1
Byte 18 bit 1 1
Byte 18 bit 2 0
Byte 18 bit 3 0
Byte 18 bit 4 1
Byte 18 bit 5 1
Byte 18 bit 6 1
Byte 18 bit 7 0
Byte 21 bit 0 1
Byte 22 bit 2 0
Byte 22 bit 4 1
Byte 23 bit 5 0
yes i coded by vcds.... but i'm not really sure the code is correct, because the string code i found on this post is for t6 models, and i'm not sure for the t5 is the same....
but I think I was wrong with cables,
i send on pin 10 the signal of my pin 4 (drl +)
and on pin 12 the signal of my pin 10 (parking light +)
is correct?
thanks
You have to use alternative view in the long coding (LCode 2) to see the tick boxes for all 8 bits in each Byte ...
