Does anyone have the same button configuration as this wheel but in a golf wheel? R or gtd. with dsg?Would this one listed fit mine in the picture? If I swapped the buttons over it would work right?
Can’t find one anywhereDoes anyone have the same button configuration as this wheel but in a golf wheel? R or gtd. with dsg?
Cheers.I’ll speak to my supplier for you
You don’t happen to know the part number for the golf wheel do you? All the ones I find have the acc on. Which do you prefer?I Have a couple of wheels i run with the same setup as yours. GTI one is from a polo and the other is from a passat i think. The main importance is making sure the buttons match what you have and the airbag hooks are the same. Both these wheels were plug and play using the standard wiring loom on the airbag. The passat wheel is away being re-trimmed ATM.
I sourced mine from Europe, both new wheels. There are a lot out the with ACC controls now. These will not work unless you swap the switches and wiring from yours to that wheel, which i have never had to do.
Sorry mate. I meant polo wheel.I dont have a golf wheel . AFAIK GTI one is a polo and the other is from a passat as i said . Never looked to see if there are part numbers on them i will look when i swap them again for you . My passat wheel is away at trimmers for a couple of weeks thow . I like them both, just nice to change between the two now and again, just like some do with wheels![]()
The steering column has a spline shaft ,you might of got it slightly out on the spline .it doesn't line up wit pins on the back .just un bolt and.move it round slightlyActually from this photo of the back of my new wheel it looks like I might have fitted it with the wrong pin holes. I just noticed there are two sets at a slight rotation from each other
You can’t rotate the wheel as there are two pins on the column which insert in holes on the wheel. If you look at the photo I posted above you can see the holes. I just hadn’t realised there were 2 sets. I’m 99% sure I’ve just used the wrong ones so it will be an easy fix when I return from this Campervan trip (I hope!)The steering column has a spline shaft ,you might of got it slightly out on the spline .it doesn't line up wit pins on the back .just un bolt and.move it round slightly
The pins are for the clock spring and they spin really easy ,they don't line the wheel up ,its the spline in the centre .You can’t rotate the wheel as there are two pins on the column which insert in holes on the wheel. If you look at the photo I posted above you can see the holes. I just hadn’t realised there were 2 sets. I’m 99% sure I’ve just used the wrong ones so it will be an easy fix when I return from this Campervan trip (I hope!)
Pins can be seen in this image that I took when I had the wheel off (pins might be the wrong terminology)
Ahh. Thanks for the info. I must have not realised I had rotated them and then tightened it up where it was. At least I can relax now as I know I can fix it. In the words of Homer Simpson “DOH!”The pins are for the clock spring and they spin really easy ,they don't line the wheel up ,its the spline in the centre .
If you look on your old wheel it might have a dot or line for the centre point .
Have a look here:The question here is, has any one tried all these GTi wheels with ACC, i know that wheels work with out it but i can not see any reference to it being done with ACC ( Auto Distance Cruise control) that is (Radar)
thats the wheel i wantJust swapped the chrome trim around the buttons for a nice piano black with R at the bottom. Looks much better than chrome with GTI but what a barsteward to get off.
