A monitor will tell you when it’s draining but won’t necessarily tell you what’s causing it. A voltage based monitor is somewhat less useful on lithium because the voltage is so flat over a wide range of SoC.
Does your battery report current flow and/or do you have a shunt in there somewhere to do that? If so, I guess it’s a case of going out there on a regular basis to look at the draw to try and puzzle out what’s causing it. If the draw is fairly constant, I guess you could turn circuits off one by one until the one responsible reveals itself. A clamp meter would be useful to work out where the current is going.
Arguably your battery protect voltage is set a little low if it managed to get down to 3% SoC I would say.
