Renogy 100ah Battery cell imbalance and written off
JB_T5.1
I have a Renogy 100ah lithium battery model RBT100LFP12-BT-UK.
Noticed battery was flat recently as had cut out however on closer inspection was low voltage on one of the four cells. When taken on a long drive it will eventually rebalance and appear fully charged however when left overnight it goes out of balance again. Screenshots below, one with engine on and the other off. Showing 2.2v on the cell in question below but think it was 0.3v when I first noticed.
I messaged Renogy last week and received this message from them this morning:
Dear Customer,
Thank you so much for your patience while we thoroughly reviewed your battery’s condition.
After careful evaluation by our technical team, we’ve determined that your battery is suffering from severe cell imbalance, which significantly impacts performance and safety. Unfortunately, this condition cannot be reliably restored through balancing or recalibration.
As your battery is outside the warranty period, we recommend replacing it with a new unit to ensure optimal system reliability and longevity
So that's a new battery then. Very disappointed as was expecting the battery to last up to 10 years and it is only 3 years old. Looking at the warranty it appears to only be 3 years which I am a couple of days beyond however it is not full replacement only a partial value based on number of months of the warranty period left, but they have offered a 6% discount on my next order! Suffice to say I shall not be replacing with another Renogy battery.
Has anyone else had this issue and is there anything else to try before I bite the bullet and replace?
In terms of new batteries been looking at the Fogstar Drift 105ah which seems good with the self heating feature and 10 year warranty: Fogstar Drift 12V 105Ah Lithium Leisure Battery
The EcoWorthy 100ah also looks very good value without self heating: 12V 100Ah LiFePO4 Lithium Battery with Bluetooth | Deep Cycle & 10-Year Life
Any other recommendations?
That's really annoying. That prorated warranty isn't something I'd seen before, it looks like it's only really a one year warranty and then declines proportional to how much is left. Feels pretty shady, if I saw something with a 3 year warranty, I really would assume it was a genuine replacement warranty. If that ten year Fogstar warranty is genuine then (assuming the company is still around in ten years), it's miles better cover than a dodgy 1-3 year partial warranty.
View attachment 314837View attachment 314838
Dear Customer,
out of interest. . . whats your setup?
whats charging the battery?
has it been left to run flat often?
do you run solar etc etc etc . . .
got any pics?
I have run it flat once this summer when away in France but that was a one off usually it is at 100%.
I have the Renogy 50A DC-DC charger combined with built in MPPT solar charging from a 200w panel so that always keeps it topped up day to day.
I learned recently that charging when they're very cold can damage them, could that be the case perhaps?
I also wonder about stuffing 50 Amps through them, seems a lot to me but I'm not qualified in battery chemistry.
Also that they don't really like being left at 100% for long periods.
I also wonder about stuffing 50 Amps through them, seems a lot to me but I'm not qualified in battery chemistry ...
That's true but the bms should stop them charging when it drops below a certain temp to protect the battery. The 50a charger actually only allows 25a from the alternator and 25a from solar when both in use and will never get anywhere near 25a from the solar. You can also reduce the current in the app and think I have mine set to 30a.
