Hi all
I know this has become a popular item now and I have just upgraded to the 50A version. However. After the install everything looked OK. A week later both my Renogy Lithium batteries are dead. The alternator light is constant red which I believe is correct, the Service light shows green??
Checking the app the charger showed boost mode and bugger all amps or watts being put out. The battery mode is set to lithium and the smart alternator wire connected and showing a current when I checked it.
So why no amps going into the battery and why did they fully discharge when not used and van driven everyday to work.
Ps. I'm currently charging the batteries via a charger and both excepting current so apear to be charging OK.
Need an idiots check list to go though to try and find out what's going wrong.
Thanks Grant
Thanks Grant
