Any help would be greatly appreciated with the below
Am just wondering if anyone has come across this issue before with a DC-DC charger. I first thought it was a faulty unit (CTEK 250SE) so changed to the RENOGY DCC50S but am still having the same issue.
When the wire from the alternator is not attached to the DC-DC charger it reads as it should (14V~ while running and 12~ while off) but as soon as I then connect this wire to the alternator input on either the CTEK or RENOGY unit the voltage drops to <10 even though the voltage at the starter battery itself stays 12V or 14V. This means that it never swaps over to charge the leisure battery.
There is a good ground connection from the starter battery to the DC-DC charger and everything else works as it should when on EHU.
Has anyone come across this before by any chance?
