EU6 150 CXHA Engine Oil Change
Depends on emission PR code on configuration sticker (under dash).
6.4 litres for PR numbers 4IE, 4BH, 4BF, 7CS, 7CY​
7.4 litres for PR numbers 7MM, 7MJ, 0GG, 0GZ​
According to the PR code above, 4BH, my CXHA should take 6.4L, but there isn't much left out of two 4 litre cans when I fill up, (and I short fill by 0.5l to stop the high oil level warning). If 6.4 litres, I should have half a can left, but I probably have less than a litre, so mine must be 7.4 litres
Reactions: mmi
I have to admit, i found the same when i changed mine a few weeks ago, i had a mare and had to drain some out so dont really know how much i put in, how many litres do you put in to avoid the reduce oil level warning?
Probably just over 7 litres, I get the level just over half way up the dipstick, and that lasts until the 10K oil changes without dropping much.
The sticker in my logbook also states 4BH, so that means it's a 6.4L one then, I never knew that there was a 6.4L and a 7.4L types to be honest.
To be honest guys I never knew this. Thought that 7.4L is the standard throughout. I put this question to Gemini AI and this is the explanation:
The 6.4-litre capacity is absolutely correct for your specific vehicle based on the technical data and the identification sticker you provided (4BH).
The reason for the difference and why your campervan requires less oil than the "standard" 7.4L usually cited for Transporters is explained below:
Why there is a difference:
PR Code 4BH: Your sticker clearly lists 4BH as one of your production codes. According to the technical specifications for the CXHA engine, vehicles with this specific code are built with a 6.4-litre oil capacity.
Emissions and Hardware: The 1-litre difference is typically due to variations in the oil sump design or different emissions hardware (such as specific DPF or AdBlue configurations) required to meet stricter Euro 6 standards like Euro 6d-Temp.
Configuration Logic: While many Transporters with PR codes like 7MM or 0GG do require 7.4 litres, Volkswagen uses different sumps across the T6.1 range depending on the exact build date and emissions targets.
Why you likely thought it was 7.4L
General Rule of Thumb: For years, the 2.0 TDI Transporter engine (especially the T6) was almost universally 7.4 litres, so this became the "standard" answer on many forums and even in some generic parts store databases.
T6.1 Transition: The T6.1 introduced these specific 6.4L variants, leading to significant confusion because the engines look identical from the outside.
The Danger of Using 7.4L
Overfilling: If you were to add 7.4 litres to your 4BH engine, you would be 1 litre over the maximum limit.
System Stress: This excess oil can cause the crankshaft to "whip" the oil into foam, increase pressure on seals, and potentially contaminate the DPF, which is an expensive component to replace.
Following the 6.4-litre specification is the only way to ensure your engine operates within the manufacturer's designed tolerances.
Well, you learn something new every day. But then I note that some members are filling up to 7.4L in their 4Bh coded engines, unless I am misreading it?
I've an oil change due soon, so I will measure exactly what goes in, and where the level is on the dipstick. Mine is 4BH, and I seem to remember it fills with very slightly less than my T5 2.5 BNZ engine, of which I got all 8 litres in even though the spec was for slightly less. (I do thoroughly drain oil for at least an hour, and jack the vehicle up to aim the dregs out of the drain hole)
Bit more from Gemini AI premium
The conflict between "official technical specifications" and "real-world dipstick readings" for the T6.1.
For your specific CXHA engine with the 4BH code, the technical data is clear, but the implementation is where it gets tricky.
Why the Two Figures Conflict
The 6.4-litre figure is the official Volkswagen service fill for PR codes like 4BH, 4IE, and 4BF. The 7.4-litre figure is for other codes like 7MM or 0GG.
The confusion arises because:
Dipstick Calibration: On some T6.1 models with the 6.4L sump, owners have reported that putting in exactly 6.4L only brings the level to the very bottom of the dipstick or doesn't show at all. This often leads people to add more until it hits the "MAX" mark, effectively putting in closer to 7.4L.
Trapped Oil: A standard oil change rarely drains 100% of the oil; some remains in the oil cooler and internal galleries. If a van's total capacity is technically 6.4L, adding 7.4L on top of any residual oil will significantly overfill it.
Component Variations: While the sump might be the same part number across models, the dipstick and dipstick tube can vary between the 6.4L and 7.4L variants. Using a "long" dipstick in a "short" tube (or vice versa) can give a completely false reading.
The Danger of the 7.4L
If you follow the forum advice and fill a 4BH engine with 7.4 litres, you risk the following:
"Oil Level Too High" Warning: This is the most common issue for T6.1 owners. The electronic sensor is very sensitive to overfilling.
DPF Issues: Overfilling can lead to oil being pushed into the emissions system, which can prematurely clog or damage your Diesel Particulate Filter (DPF).
The Recommended Practical Approach
To avoid both a "too low" reading and an "overfill" warning, most specialists recommend a staged fill:
Initial Fill: Add 6.0 Litres first.
Settle: Let the van sit on perfectly level ground for at least 10–15 minutes after a short run to allow the oil to drain back into the sump.
Check: If it’s on the stick at all, you are safe to drive.
Incremental Topping: Add in 200ml increments until you are roughly halfway up the cross-hatched area.
Note: For the T6.1, it is actually safer to be at the middle of the dipstick than at the absolute maximum, as the oil level can "rise" slightly during DPF regeneration cycles due to fuel dilution.
To clarify, and add to the AI stuff, I always add about 75% of what I know has to go in, run the engine briefly to fill the oil filter etc, then keep topping up and checking, maybe 6, 7 or 8 times until I'm happy with the level.
Very easy to add more, far more difficult to remove some!
