Turned up some spacers for the floor rails to fit in the troughs. Then fitted the ply packers, insulation, ply floor and finally bolted down the rails.
:thumbsup:Good work, no messing around
What’s this gizmo??
img_0457-jpg.24540
It's a dimmer switch for the lights. It's not connected yet but it should be touch sensitive.
It's looking good, those front seats are bright, are you doing the bed in the same colour?
The van is nearly finished now but this thread is well behind so I'll try and get it up to date.
After checking the hole alignment the ply came up and insulation then went down.
once that was trimmed, floor back down followed by the Altro vinyl. Finally the new step and light went in.
Shot from below of the spreader please
Now the floor was in I finished the lining, including cutting new panels, bonding packers to the ceiling and covering everything in carpet.
I wasn't happy with the finish around the windows as I had to line it once the windows were in. I was also thinking of fitting curtains but was never really happy with that so to sort both issue I bit the bullet and bought Vanshades. The wallet took a bit of a hit but I did get the unfinished ones and carpeted them myself so saved a few quid anyway. No photos of this though.
The Evo motion furniture also arrived so I started sorting that. Again no photos. It is very good furniture and fits together very well. However, a word of warning the instructions are next to useless. I spent a lot of time looking at photos on their website to try and work out what went well.
The next job which I though would be fairly easy was to fit the internal water tank. I'd seen @Fish mod with the level sender so that was first. Then measure, measure, measure and drill the holes for the pipes!!
Batton glued to support it
First attempt at the piping. Feed and fill from the top and feed and drain from the bottom
I found the pipe kept slipping off when the jubilees were clamped as the outlets kept crushing. These inserts from screwfix worked well
New fitting
Batten glued to support it.
New fitting.
Are these tanks potable? I ask as I’m keen on an internal that doesn’t take up valuable cupboard space.
And where are you planning on fitting your filler point?
I'm not sure whether I'll use it as drinking water. That was the plan but I'll see if it leaves a taste in the water or not. It's out of sunlight so I don't see why not.
I've put the filler cap in the back of the units and I'm running the pipe down the back of the units.
Filler points cut
I had to mod the units to fit under the Vanshades pods
Fittings and pipework in
The other pipe is the shower point feed
