@RikParr73
as
@VanDamMan said above.
that's fine, but make sure its the same battery chemistry and type/size.
preferably the exact same battery.
also try to have both batteries at similar SOC when you connect them. (as large currents can flow between a flat and full battery)
normally 50A Anderson connectors are used to connect batters together.
remember to fuse all battery connection.
so you need to fuse the outgoing leisure battery POS terminal.
and also the 2nd battery terminal.
more info on building a battery box here:
12v Lithium Leisure Battery Box 138Ah 1766Wh -- How I Done It -- It's about time that I got this long-overdue project sorted out. The missing parts are on order and completion is in sight . . . . . . . . ready for the Post Pandemic 2020 Camping Trips (Hopefully) This is where it started. p1...
www.t6forum.com
the CTEK D250 has around 20A charge current, so that's ok for two battery's together.
remember that if the second battery is low and you plug it in to the vans leisure battery . . . . current will flow from one to another until they equalize . . whether the CTEK is running or now.
the 50A Andersons will start to get hot above 40A so bear that in mind.
also make sure you use decent fat battery cable for the interlink. and make sure its fused at 50A or below ( depending on the size if the interlink cable )
Dellmassive`s -- "how I Done It" -- Thread
Kit List And Stuff -- How I Done It & What I Use --
VIP Membership | VW T6 Forum - The Dedicated VW Transporter T6 Forum
For Sale - Summer-weekend-t6f Limited Edition External Stickers
For Sale - T6F Flags
