If you click on the link @Pauly put in his message it will take you to them in the forum shop.I need these too, I’ve accidentally bought the smaller version. Anyone know where to buy them?
VCDS will do it . . . .I have wired the rear speakers on my T6 2018 into the brown connector spare pins above and below the wires for the front speakers. The speakers work, however to get the full benefit I would like to fade them. I have been to a local garage and they were unable to instal the fade onto the head unit, suggesting there software was 2017 and may not have the option to load this on this model! Has anyone any ideas how I can get this to work?
Are you saying thjat just holding down the power button enabled you to find the fader option or that the HX2 cable AND the hard reset did the trick? I'm guessing the latter????Just sharing my experience....
I bought an ODB11 dongle and attempted to code my rear fader. I tried a number of things - there isn't an app to change this like some of the other common adaptations and when I eventually found information on the web and tried that it didn't work - came up module coded incorrectly.
On my previous van I used VCDS following the instructions on this post and it worked fine.
So, I have just bought another genuine VCDS HEX2 cable (sold the last one) and again following these instructions it worked perfectly first time.
I found by holding down the power button on the stereo for 20 seconds made it hard reset, then locked and unlocked the van and the fader option appeared.
VCDS +1
ODB11 has been relegated to the glove box to be used on my phone if I ever get an EML whilst out and about. VCDS will be kept at home for the 'serious' coding jobs.
You still need to change the coding via VCDS first.Are you saying thjat just holding down the power button enabled you to find the fader option or that the HX2 cable AND the hard reset did the trick? I'm guessing the latter????![]()
Just had a replacement head unit from VW on my 2017 T6 under the “all-in” extended warranty and service plan. They refused to activate the rear speakers /fader option like I had on the one they removed.Hi, had some rear speakers fitted to my new t6. The speakers work but the fitter was unable to re code the head unit to enable the front / rear fader. Any suggestions... ?.
What was the fault with the original radio?Just had a replacement head unit from VW on my 2017 T6 under the “all-in” extended warranty and service plan. They refused to activate the rear speakers /fader option like I had on the one they removed.
Pauly is an absolute gent and did it for me on his VCDS laptop while I was passing by.
Thanks Pauly, nice to meet you.
