The solar panel on my van doesn't appear to be charging anymore (last 'successful' cycle was 3 weeks ago). Oddly though, when looking at the Victron app first thing in the morning, there is voltage (but no watts / amps due to lack of sunlight), but an hour or so later, there's nothing.
I disconnected the MC4 connectors this morning to test the panel directly and got voltage @ 07:45, but when I checked again @ 09:11, I got nothing (multimeter probes are correctly inserted and contacting metal). I'm not sure what brand / rating the panel is (the black box at the back is labelled PV-XC502, which leads me to believe it's not perhaps the best panel in the world)
Would I be correct in assuming that the panel has failed, or am I doing something stupid?
If it has failed, given it appears to be bonded down, is the best way to remove using a windscreen removing wire?
Thanks for any advice
