Direct TPMS Retrofit
A full scan would be better... can't even see the TPMS module you try to use
Sorry, that's just the instruments fault section from Adams instrument cluster scan as referenced in my post,
My scan is here
Saturday,18,December,2021,16:27:44:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 21.9.0.2 (x64)
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZDH059443 License Plate:
Mileage: 214830km-133489mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 0D 10 15 17 18 19 20 25 37 3C 5F 65 69 78
VIN: WV2ZZZ7HZDH059443 Mileage: 214830km-133489miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
0D-Slide Door, Left -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
37-Navigation -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
65-Tire Pressure -- Status: OK 0000
69-Trailer -- Status: OK 0000
78-Slide Door, Right -- Status: OK 0000
Address 01: Engine (J623-CCHA) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 FL HW: 03L 907 309 M
Component: R4 2,0L EDC H44 3306
Revision: 26H44--- Serial number: 00000000000000 CVN: 3DBC56CA
Coding: 0125401A233400080000
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_ECM20TDI01103L906019FL 003002
ROD: EV_ECM20TDI01103L906019FK_003.rod
VCID: 7AFB47EFFDDF50590F-802E
VINID: 9E60AAAAA1D8A946001491040C7EFB9102
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BT 300 045 P HW: 0BH 927 711 C
Component: DSG DQ500-7F H07 1801
Revision: 00H07V01 CVN: 31A3139E
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_001_VW37.rod
VCID: 428BFF0FD58FD89917-8016
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 K HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0110
Revision: 00H43001
Coding: 108724AD09A9089E24A690758A6110
Shop #: WSC 02756 790 49152
VCID: 3A7B87EFB55F90594F-806E
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 7E5 907 040 AC HW: 7E5 907 040 AC
Component: ClimatronicT5 H19 0406
Revision: 00001003
Coding: 0004000102
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis.rod
VCID: 69D908A38879EBC1F6-803C
Slave 1:
Subsystem 1 - Part No SW: 7E5 907 049 B HW: 7E5 907 049 B
Component: Heckbedienung H10 0202
Serial number: BHB-0011110120015074
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 193161504
Coding: A0B279B82E612413B3288ED06EEB8EDDF09060FF60846040300403030800
Shop #: WSC 02737 022 137061
VCID: 2A5BB7AF45FF20D93F-807E
Subsystem 1 - Part No: 5K7 955 547
Component: RLHS 200618 0 50 0107
Coding: 0728DD
Subsystem 2 - Part No SW: 7E0 959 801 C HW: 7E0 959 801 C Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 003 3313
Serial number: --------------------
Coding: 050000
Subsystem 3 - Part No SW: 7E0 959 802 C HW: 7E0 959 802 C Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 003 3313
Coding: 040000
Subsystem 4 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 5 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Subsystem 6 - Part No: 7E1 951 172
Coding: 000000
Subsystem 7 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H06 0022
Serial number: 50000000000000366248
Coding: E30000
Address 0D: Slide Door, Left Labels: Redir Fail!
Part No: 7E0 959 243 D
Component: Schiebetuer-SG 407 0328
Shop #: WSC 02756 790 00000
VCID: 306FA5C7A3235A09F1-8064
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 39361628900641
Coding: 0021191111
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_EPHVA18VW364GP00 001007
ROD: EV_EPHVA18VW364GP00_VW32.rod
VCID: 377D9EDB8E4D8D31B0-8062
1 Fault Found:
12718592 - Databus
U1121 00 [009] - Missing Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 154
Mileage: 214837 km
Date: 2021.12.18
Time: 20:29:49
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 E HW: 7E0 959 655 E
Component: VW10Airbag00C 008 0016
Revision: -------- Serial number: 003PJ0011EYB
Coding: 000000000000000000000000000000003043
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 387F9DE783538249B9-806C
Crash sensor for side airbag: driver side:
Serial number: 3495ZRB405B18AIC48CF
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3505ZRB404V18E5G9GF.
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 980 G HW: 7E0 920 980 G
Component: KOMBI H06 0405
Coding: 760F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 2F6DA6BB761D45F1E8-807A
Address 18: Aux. Heat Labels: 7E0-815-071.clb
Part No: 7E0 815 071 B
Component: J737__Standheizung 0605
Revision: 00085000 Serial number: 09019275F00000
Coding: 0000031
Shop #: WSC 02757 790 00000
VCID: 24475997E7DBF6A905-8070
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 042307
VCID: 68DF0DA79B73D2C9E9-803C
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 F HW: 7E0 857 511 C
Component: FLA H10 0003
Revision: AA001001
Coding: 010101E200000000000000
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_HighBeamAssisAU316 001004
ROD: EV_HighBeamAssisAU316.rod
VCID: 2D51BCB37C1137E1DA-8078
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H06 0405
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADB77AF8D7FE0D9FF-803E
Address 37: Navigation
Cannot be reached
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0495116638
Coding: 03032202
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_HREntryHella 001028
ROD: EV_HREntryHella_VW37.rod
VCID: 3D718CF3AC71A7616A-8068
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0475999063
Coding: 030322
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 G HW: 5C0 035 680 E
Component: MU-S-ND-ER H31 0478
Serial number: VWZAZ2T5057511
Coding: 06450001FF00000001110201008808001F0100D600200101CF
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 2541449324E10FA112-8070
Data carrier:
Subsystem 1 - Part No SW: 5NA 919 866 BK HW: -----------
Component: ECE AS 2022 --- 1730
2 Faults Found:
15360256 - Component Protection
U1101 00 [009] - Active
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 154
Mileage: 214837 km
Date: 2021.12.18
Time: 20:29:49
Voltage terminal 30: 12.9 V
0001 - Antenna 1 for Radio
B1119 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 154
Mileage: 214837 km
Date: 2021.12.18
Time: 20:29:49
Voltage terminal 30: 13.0 V
Status of antenna 1 for radio-Antenna current: 0 mA
Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H06 0011
Serial number: 30000000433896
ASAM Dataset: EV_RDKBERU30 005005
ROD: EV_RDKBERU30_005.rod
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 H HW: 1K0 907 383 G
Component: Anhaenger H12 0130
Revision: 3B001001 Serial number: 00000486053219
Coding: 4100000101000000
VCID: 326BAFCF6D2F681987-8066
Address 78: Slide Door, Right Labels: Redir Fail!
End-------------------------(Elapsed Time: 03:54)--------------------------
So after a long and arduous journey, I've finally got direct TPMS working (ish) with my instrument cluster.
Originally, my cluster wouldn't show anything to do with the direct TPMS and threw up an error code. For info, it was 7E0 920 980 G H06 0405 - a T5.1 2D colour premium cluster. @dnoermann's similar cluster on software 0509 apparently worked fine - so I set about trying to find a file for 0509 which I eventually managed to get my hands on. Firstly, it wouldn't flash and I needed to change the SA2 key, then the flashing failed and the cluster stopped working completely, I couldn't start the van, MOT ran out, all appeared to be lost.
Thankfully, @Punkvw stepped in, and tried his best to revive my cluster remotely with some special flash files which unfortunately didn't work. We believe 0509 wasn't actually compatible with my cluster hence the failure. After a bit of discussion we decided the best way forward was to convert my cluster to a 3D one, so I bought a donor 3D cluster from a Passat CC (3C8 920 981D H04 0611), it was actually a 2D cluster but a high enough software version to allow being flashed to 3D. Anyway, the donor cluster arrived this morning, I drove down to him in Stevenage with both clusters and he worked his magic while I stuffed my face at McDonalds. I now have a fully working 3D colour cluster that supports direct TPMS and everything else I plan on retrofitting in the future. I am over the moon and can't thank him enough! I also asked him to change the graphics in the EEPROM to 0x0E (T5.1) thanks to the info in previous posts so I get the van display for TPMS :D My cluster now identifies as a 7E0 920 880 S H04 1109 - strange that the HW version went down, I can only assume that bit comes from the screen itself.
If anyone else has the same predicament as me, he can upgrade your 2D colour cluster to a 3D one with a donor cluster. And for everyone else, he can also fit you a 3D colour cluster outright, just drop him a message, I can't recommend him enough.
So, now to explain the working (ish) bit, the eagle eyed amongst you may have noticed no wheel pressures are being displayed. I've taken it for a little spin (on a private road :whistle:) and nothing changed. The full install has been there for nearly a year (just operating blindly due to an unsupported cluster), so I'd have thought it'd have sorted itself out by now. The sensors appear to be detected from the measuring blocks in VCDS, but autolocation hasn't happened. I can't remember the part numbers, but I did get the info from this thread after someone ordered the wrong ones, although they were Aliexpress specials. I'm going to try and borrow a TPMS scanner and try and manually configure them and see how we get on. It seems a few people have had this issue too, it could of course just need a longer drive to kick them into life.
I've at long last got this fully working on my van...
The sensors would not auto locate at all, but were all being detected as the info was visible using VCDS. The predicament I had was I didn't know which sensor ID was on which wheel. I got the local garage to use their TPMS device to try and identify them but it wasn't working, I suspected because they were setting it as a 2012 Transporter which never would have came with this setup, as it was nearly closing time I told them to give up and I bought an Autel MaxiTPMS TS408. For some reason I can't get this to detect any of the sensors either! It will happily read the ones on my other car (Renault Koleos) but refuses to read the van ones.
Anyway, I eventually had a brainwave, as I can see them in the measuring values in VCDS I just dropped the tyre pressures one wheel at a time to identify them, which worked.
I then tried to follow this procedure...
i know why doesnt work 4u ,
You have to added all sensors ID manual and match with each wheel .
so read ID of all your sensors .
go to 65 / adaptation / add ID of your sensor and add which wheel is it . done .
ignition off 10sek and back on
again go to 65 / adaptation / add ID of your next sensor and add which wheel is ..
do that 4 times
so after that your module will c all sensors check picture .
Now do calibration in 65 module / basic settings
i dont have a special tool so i use strong magnet
pickup of list calibration tyle 01 and go to 01 wheel with magnet
30sek , pressure icon will flashing on speedometer click stop
type 02 and go to wheel 02 and do the same .
03 and 04 and go for drive .
i had the same problem
take me few days to fine solution , and now one can help
all people said , that easy , just work strait . (NO DOESN'T ! )
if you have MODULE used or new with new sensors we have to added to each wheel in adaptation . :)
Do that and will work 4 you.
All the best.
...but it wasn't storing the information.
In the end I tried doing each wheel's sensor ID then position, but without turning off ignition for 10 seconds between each one, and it has sprung into life. No need for the calibration either in my case
IMG20220830170235.jpg b
Nothing I do ever seems to be straightforward but I've finally got there....and as for why the MaxiTPMS won't read the sensors, its a mystery...
Hi, I'm Amir from Malaysia. This thread has been interesting for me as I've been wondering how to solve my issue of not be able to see the car image in my 3d color cluster for the Direct TPMS menu in mfd. The supplier for my 3d color cluster said simply because Sharan never had TPMS from factory.hence no image available to be displayed. But the vehicle door status all working fine.
I have 2013 sharan 2.0tsi. I've retrofitted direct TPMS, Composition Media, 3D Color Instrument, Blind Spot with RTA, 1k8 Parking module, Memory Driver Seat, Dedicated 7E0 HBA, Easy Open Tailgate, Batteri Regulator, Scirocco Auxiliary Display, Rear Climatronic Panel, Wireless Charger....
here's my vcds fullscan. Hopefully you guys here can help me. thank you
Code:
VIN: WVWZZZ7NZDV0BENZIN   License Plate: BENZINKOPF
Mileage: 15930km-9898mi   Repair Order: 220127
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 18 19 20 25 2B 2E 36 3C 42
          44 46 47 4C 4F 52 53 55 5F 61 62 65 6C 6D 72 A5 B9 BE BF
VIN: WVWZZZ7NZDV0BENZIN   Mileage: 15930km-9898miles
05-Acc/Start Auth. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Not registered 0011
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
B9-Aux. Display -- Status: OK 0000
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
   Part No SW: 06J 906 027 DJ    HW: 06J 907 309 A
   Component: MED17.5.2        06 2269
   Revision: P3H07---    Serial number:
   Coding: 0404000C1C070160
   Shop #: WSC 00020 790 00000
   VCID: 76A0EAE901C0FC396B-8022
   VINID: 9E69EAAAA1DEA949800841481C276FDCB1
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 058 T    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3515
   Revision: 05651213    Serial number: 00001211151749
   Coding: 0000020
   Shop #: WSC 00020 000 90108
   VCID: 2B160B9D8A02F1D1C4-807E
Address 03: ABS Brakes        Labels: 7N0-614-109.clb
   Part No SW: 7N0 614 109 P    HW: 7N0 614 109 P
   Component: J104   C3 450M VDA1 0030
   Revision: --H07---    Serial number: 00000006425793
   Coding: 0003896
   VCID: 3A383ED9755858594F-806E
Address 05: Acc/Start Auth. (J518)       Labels:| 5K0-959-434.clb
   Part No SW: 5K0 959 434 F    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 093 1202
   Revision: 00093000    Serial number: 0344538672
   Coding: 13100C
   ASAM Dataset: EV_KESSYPQ35G A02717
   ROD: EV_KESSYPQ35G_A02_VW31.rod
   VCID: 383C24D183544A49B9-806C
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 7N0 907 044 F    HW: 7N0 907 044 F
   Component: Clima-Sharan  H01 0202
   Revision: 00001K03
   Coding: 0210154558
   ASAM Dataset: EV_ClimatronicSharan A01005
   ROD: EV_ClimaAutoSharaBasis.rod
   VCID: 332613FD9A32A9118C-8066
   Slave 1:
   Subsystem 1 - Part No SW: 3AD 907 049 A    HW: 3AD 907 049 A
   Component: KBT-H  H09 0020
   Serial number: CG11068266
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
   Component: BCM PQ35 M    021 0068
   Revision: BC021001
   Coding: 46590ABBDD2BFBC350DA25C9310009EC47FD1408777DADB0E4844220E2C1
   VCID: 3E3032C9A970747973-806A
   Subsystem 1 - Part No SW: 7N2 955 119 A    HW: 7N2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    121015  31  0032
   Serial number:         121024214914
   Coding: 004DBD
   Subsystem 2 - Part No SW: 5Q0 955 547     HW: 5Q0 955 547   Labels: 5Q0-955-547.CLB
   Component: RLFS  024 0042
   Serial number: Y12M11D27H21M39S02S4
   Coding: 069597
   Subsystem 3 - Part No: 7N0 951 171
   Component: DWA-Sensor 00  002 0205
   Coding: 000000
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 1K8 919 475 B    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0479
   Revision: --------    Serial number: 39491531403690
   Coding: 0121267011
   ASAM Dataset: EV_EPHVA2CVW364GP00 001010
   ROD: EV_EPHVA2CVW364GP00.rod
   VCID: 393A21D5B85E534146-806C
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 16111202720002
   Coding: 010180
   VCID: 271EF7AD56EAD5B120-8072
   Part No SW: 7N0 959 655 C    HW: 7N0 959 655 C
   Component: VW10Airbag00M H11 0014
   Serial number: 003LGPQ8V001
   Coding: 00304D
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 3FCE4FCDA67A7D7178-806A
   Subsystem 1 - Part No SW: ---            HW: ---
   Component: S.Sens.Fahr.V  --- ---
   Serial number: 3493ETS60E09C11179DY
   Coding: 000000
   Subsystem 2 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.V  --- ---
   Serial number: 3503ETS607C8D1E179D1
   Coding: 000000
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 3 - Part No SW: ---            HW: ---
   Component: S.Sens.Fahr.H  --- ---
   Serial number: 3513ETS60BD9C1117DD+
   Coding: 000000
   Passenger side rear thorax airbag crash sensor:
   Subsystem 4 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.H  --- ---
   Serial number: 3523ETS6081641E179DP
   Coding: 000000
   Crash sensor for front airbag: driver side:
   Subsystem 5 - Part No SW: ---            HW: ---
   Component: F.Sens.Fahr  --- ---
   Serial number: 35540TS609E1FE616DD0
   Coding: 000000
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 5K0 953 521 CM    HW: 5K0 953 569 E
   Component: LENKS.MODUL   014 0140
   Revision: FF010041    Serial number: 20121116100931
   Coding: 301A240008
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79BAE1D5F8DE934106-802C
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 5NA 959 442 B    HW: 5NA 959 442 B
   Component: E221__MFL-TAT  H06 0025
   Coding: 2D0000
   Part No SW: 7N0 920 880 K    HW: 7N0 920 880 K
   Component: KOMBI         H05 1114
   Coding: 110D030000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
   VCID: 3B363BDDB262615154-806E
Address 18: Aux. Heat        Labels: 1K0-815-071.clb
   Part No: 5K0 963 271 B
   Component: Zuheizer        051 2706
   Revision: 00051000    Serial number: 09021535000000
   Coding: 0000112
   VCID: 2E100289B91084F9E3-807A
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 BC    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1663
   Revision:   H56       Serial number: 15101500F11091
   Coding: 468023
   VCID: 72A8D6F9ADA8E01947-8026
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 105
                    Reset counter: 255
                    Mileage: 14836 km
                    Time Indication: 0
                    Date: 2022.01.07
                    Time: 00:20:28
   Revision: AA001001
   Coding: 0202010300000000000001
   VCID: 2D1205857C16FFE1DA-8078
   Component: IMMO          H05 1114
   Coding: 000007
   Shop #: WSC 00046 000 00000
   VCID: 6A98CE998D7828D9FF-803E
Address 2B: Steer. Col. Lock (J764)       Labels:* 5K0-905-861.clb
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 12000263247003
   Coding: 4900000000000000
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2F2E1F8D761A8DF1E8-807A
Address 2E: Media Player 3 (J650)       Labels:. 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7663856043
   Coding: 010100
   VCID: 2A180E9945F8E8D93F-807E
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 B    HW: 3C0 959 760 B
   Component: Sitzverstellung     0701
   Revision: 00003000    Serial number: 00000000000000
   VCID: 2C1408818F0CF6E9CD-8078
5 Faults Found:
02327 - Position Sensor for Front Seat Height Adjustment (G438)
            011 - Open Circuit
02328 - Position Sensor for Rear Seat Height Adjustment (G439)
            011 - Open Circuit
01916 - Lumbar Support Fore / Aft Adjustment Sensor (G375)
            011 - Open Circuit
01915 - Lumbar Support Height Adjustment Sensor (G374)
            011 - Open Circuit
01330 - Central Control Module for Central Convenience (J393)
            004 - No Signal/Communication
   Serial number: 0495886885
   Coding: 04031202
   ROD: EV_HREntryHella_VW32.rod
   VCID: 3D3235C5AC766F616A-8068
   Serial number: 0503974197
   Coding: 040312
Address 42: Door Elect, Driver (J386)       Labels:. 7N0-959-793.clb
   Part No SW: 7N0 959 793 G    HW: 7N0 959 793 G
   Component: TSG FA        H03 0553
   Revision:             Serial number: 0000044585295
   Coding: 01152E20DF01411011
   VCID: 46C05A29F1A02CB93B-8012
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 7N0 909 144 P
   Component: EPS_ZFLS Kl. 275    3305
   Revision: 00H21000
   VCID: 40CC4C311384028901-8014
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 5K0 035 456 C    HW: 5K0 035 456 C
   Component: KonzernAmp 8K H07 0202
   Revision: --------    Serial number: EAA086A0026825
   ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
   ROD: EV_AudioVerst8KanalBNO1_VW12.rod
   VCID: 2A180E994DF8E8D93F-807E
Address 4F: Centr. Electr. II (J520)       Labels:. 1K0-907-532.clb
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1663
   Coding: 050A0500
   VCID: 6FAEDF8DBE9ACDF1A8-803A
   Subsystem 1 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H04 0220
   Serial number: 0123456789ABCDEFGHIJ
   Subsystem 2 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J394EE20SKB13  H04 0220
Address 52: Door Elect, Pass. (J387)       Labels:. 7N0-959-792.clb
   Part No SW: 7N0 959 792 G    HW: 7N0 959 792 G
   Component: TSG BF        H03 0553
   Revision:             Serial number: 0000044559479
   VCID: 45C25D25CCA627A132-8010
Address 53: Parking Brake        Labels: 3AA-907-801.clb
   Part No SW: 3AA 907 801 H    HW: 3AA 907 801 H
   Component: J540 EPB4  VW-86594 0010
   Revision:   H19       Serial number: 00000000605996
   Coding: 0024157
   VCID: 36202AE94140BC39AB-8062
Address 55: Headlight Range (J745)       Labels:. 5M0-907-357-V3.clb
   Part No SW: 5M0 907 357 F    HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0111
   Revision: --------    Serial number: --------------
   Coding: 053200000B000200
   ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
   ROD: EV_HeadlRegulVWAFSPt_VW32.rod
   VCID: 373E27ED8E4A4531B0-8062
   Left_headlamp_power_output_stage:
   Subsystem 1 - Part No: 1T0 941 329   Labels: 3D0-941-329.CLB
   Right_headlamp_power_output_stage:
   Subsystem 2 - Part No: 1T0 941 329   Labels: 3D0-941-329.CLB
Address 5F: Information Electr. (J794)       Labels:* None
   Part No SW: 5K7 035 200 H    HW: 5K7 035 200 H
   Component: MU-S--ROA     H31 0359
   Serial number: VWZAZ2S5325164
   Coding: 02240800FF00000001110006000900A39F0104C60100010001
   VCID: 291AF19548FEE3C136-807C
2 Faults Found:
15360768 - Component Protection
          [Anti-theft protection - component protection active (0xEA6300)]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 30
                    Mileage: 12231 km
                    Date: 2021.12.06
                    Time: 23:09:13
                    Voltage terminal 30: 11.9 V
3077 - Telephone baseplate
          B1051 13 [008] - Open Circuit
          [Bracket for mobile phone holder - open circuit]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 18
                    Reset counter: 201
                    Mileage: 12231 km
                    Date: 2021.12.06
                    Time: 23:09:13
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AN
   Component: Batt.regelung H56 1663
   Coding: 0224085A
   VCID: 71AAD9F5A8AEDB01BE-8024
   Subsystem 1 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0180
   Serial number: 00000000001490726965
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 H    HW: 7N0 959 794 H
   Component: TSG HL        H01 0553
   Revision:             Serial number: 0000131364399
   Coding: 01006C200001411001
   Shop #: WSC 00020 790 12345
   VCID: 48DC5411FBB43AC9C9-801C
   Serial number: 40000000451190
1 Fault Found:
8397826 - Rear Right TPMS Sensor
          C1053 31 [009] - No Signal
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 161
                    Mileage: 15936 km
                    Date: 2022.01.27
                    Time: 10:53:02
                    Vehicle speed: 24 km/h
                    Outside temperature: 30.0 °C
                    Reception level antenna 1: 470 mV
                    Offset level antenna 1: 250 mV
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
   Part No SW: 7N0 907 441 B    HW: 7N0 907 441 B
   Component: VW428 RVC Mid H04 0040
   Coding: 01240801AA01000700
   ASAM Dataset: EV_CamSysRearPANAVW428 002002
   ROD: EV_CamSysRearPANAVW428.rod
   VCID: 302C1CF16B249209F1-8064
2 Faults Found:
9591827 - Video Signal Line
          B125C 13 [008] - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 8
                    Reset counter: 185
                    Mileage: 14020 km
                    Date: 2021.12.27
                    Time: 14:18:16
                    passive
10489856 - No Basic Setting
          B2010 00 [009] - -
          [RearView system not calibrated]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 33
                    passive
Address 6D: Trunk Elect. (----)       Labels:| 7N0-959-107.clb
   Part No SW: 7N0 959 107 E    HW: 7N0 959 107 A
   Component: HDSG-Modul    H11 0243
   Revision: 41011001    Serial number: 297200524
   Coding: 0733334002
   ASAM Dataset: EV_HDSGVW428 201138
   ROD: EV_HDSGVW428_VW36.rod
Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-794.clb
   Component: TSG HR        H01 0553
   Revision:             Serial number: 0000131364461
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3AA-980-654.clb
   Part No SW: 3AA 980 654 D    HW: 3AA 980 654 A
   Component: MFK_Gen1      H09 0300
   Serial number: 0187634102
   Coding: 01000000000202100000040000010100
   ASAM Dataset: EV_47X 001639
   ROD: EV_47X.rod
Address B9: Aux. Display (J285)       Labels:* 5C5-919-527.clb
   Part No SW: 1K8 919 527 B    HW: 1K8 919 527 B
   Component: ZUSATZANZEIGE H08 0003
   Coding: 05
   ASAM Dataset: EV_Auxi_Disp_Unit_UDS_VDD 001010
   ROD: EV_Auxi_Disp_Unit_UDS_VDD.rod
Address BE: Slid. Door Rear Left (J558)       Labels: 7N0-959-244.clb
   Part No SW: 7N0 959 244 A    HW: 7N0 959 244 A
   Component: Schiebetuer_l 005 2314
   Serial number: 12457609
   ASAM Dataset: EV_AST A03704
   ROD: EV_AST.rod
Address BF: Slid. Door Rear Right (J731)       Labels: 7N0-959-244.clb
   Component: Schiebetuer_r 005 2314
   Serial number: 12457614
   ROD: EV_AST.rod
End----------(Elapsed Time: 02:24, VBatt start/end: 12.4V/12.3V)-----------
Looks like your module (65) hasn't been activated in the Can Gateway (19).
The tick on the INSTALLATION LIST.
Can you also post picture of your TPMS menu entry on your Instrument Cluster?
Thanks Robert for the reply. Hurm. I'm not sure if I did miss the Gateway Installation List. I will check again later. But seems there's no effect on the TPMS view etc.
You need to edit your EEPROM and change your vehicle model as per my YT video.
VDOeditor is probably the best.
Taking into account your rear sliding doors the best choice seems to be T5 but by all means you should experiment with other models as well.
See below, but you can do that without VAG-TACHO and read your EEPROM content directly from the chip.
Direct TPMS on T5.1 cluster is a little bit tricky.
For example this cluster works no problem
7E0 920 880 J H04 0509
but this one doesn't work.
So maybe your SW and/or HW version is not compatible.
7E0 920 980 NX H03 0605
Hello! I have a VW T5.1 with the 7E0 920 880 cluster. But there is no 65 TPMS to activate in the installationslist? Do I need to install the recieving unit or Is my cluster not compatible?
Can you post your complete VCDS AUTOSCAN?
Sorry mate, I completely missed your reply.
Your BCM would need to be upgraded to a T6 variant (7E0 937 090 B or 7E0 937 090 C).
Your one is not compatible:
SW: 7H0 937 087 H
HW: 7H0 937 087
H47 0254
BCM upgrade is a very simple process so no worries there.
I am not sure about your Instrument Cluster.
SW: 7E0 920 880 C
HW: 7E0 920 880 C
H04 0226
You would need to try and see if it is compatible.
SW: 7H0 937 087 H
HW: 7H0 937 087
H47 0254
SW: 7E0 920 880 C
HW: 7E0 920 880 C
H04 0226
Ok, how do I upgrade the BCM?
Ah! I need to swap it. I'll see if I can get hold to one of these bcm's. Thank you!
I swapped the BCM, i lost the MFSW function on the right side of the steeringwheel and I can't program the remote controls.
