Might be worth a try @cmvandrunen I was able to change the splash screen successfully but not the fader option.
@Pauly, cables all run in and ready to go, do you recall which of the empty sockets is left/right speaker?Yes on the standard setup on vans & kombis, there are four speaker inputs on the back of the stereos - front left/right which are used & rear left/right which are empty
You need to install additional wires to new speaker location, remove stereo and fit new cables into the empty terminals on the existing quadlock connector on rear
Heres the connector before i added my rear speakers
and heres one of the wires with pin connected on end ready to insert into plug assembly
Its worth noting that after connecting additional speakers in they will work but to function properly the radio will need to be coded with VCDS (vagcom) to accept new speakers and this will activate the fader/balance menu in the radio to give you additional adjustments
@shylock i have VCDS if you would like speakers coded
Thank you very much
Cheers Paul. Whatever’s easiest for you. I’m in the yard in the morning, or I can come to the unit? I just got the head unit out, purple pin out but couldn’t get the yellow block out, it was getting dark and I’m just going out so didn’t want to force anything. All back together now, will try again tomorrow.I will take the laptop to work with me tomorrow just give me a call when your ready or I will be passing by Exeter street as some point if your at work all day ?
Thanks @PaulyA pillars and roof is prob easier
You need these pins
To go into this block
And you need to slide out the purple pin in picture as this is what locks the pins in place after u have clicked them in
Can anyone provide a link for where to get these said pins from??
Four Genuine Volkswagen Crimp Connectors For Stereo Quadlock / FuseboxCan anyone provide a link for where to get these said pins from??
What if i disconnect it from the amp en connects the wires direct from head unit to rear speakers. Wil this work? And if the fader option appears than reconnect the amp.
hello, I’m adding some rear speakers to my T6 - wiring loom has been put in place by camper king who converted the van for me.
