T6.1 Adding rear speakers to a Composition Colour, How do?
If that pic has come from the forum then if you point me to the diagram i will double check everything and edit/correct as necessary
Hi Paul,
This is the link to the diagram I found in the forum and was confirmed correct by @Absolut5
It was an attachment to post 290 on Adding Rear Speakers to OEM Headunit and enabling Fade
In saying that I heve seen elsewhere that it is actually correct (at least for a T6), so now I am really confused.
I am probably just going to swap the cables over at the back, and assume I have everything correct at the head unit end.
Hi Paul,
Well it turns out that it was me that had the left and right rear wiring the wrong way around :(. I pulled the head unit out and saw my error. Repinned the green and purple into the correct places and all sorted :)
What an excellent forum !
