ACC & City Braking - How Its Done -
what is it?
Adaptive cruise control (ACC)
Adaptive cruise control (ACC) is a speed control system with intelligent control of the vehicle speed.
The system accelerates and decelerates comfortably. Adaptive cruise control is a combination of a speed
and distance control system.
Structure and function:
The radar sensor fitted in the front of the vehicle continuously measures the distance and speed of the vehicle
driving in front. Using the ACC controls on the multifunction steering wheel, the system can be activated and
deactivated, and the required speed and following distance can be set.
In vehicles with dual clutch gearbox (DSG), braking takes place to a standstill depending on the situation. ACC maintains a preselected speed and a defined distance, accelerating and decelerating automatically. Automatic moving-off is not possible.
The dash panel insert displays all relevant information about the system such as the required speed and warning messages. The driver is solely responsible for the behaviour of the vehicle in all driving situations. He/she can influence the driving situation at any time by switching off the ACC, or braking or accelerating himself/herself. The ACC is subject to system limits during driving. If these limits are reached or exceeded in the driving situation, the driver is informed and presented with a visual message to take over the function.
Operating limits:
If the detection capability of the radar sensor is impaired due to heavy rain, snow or dirt, the distance control and
speed control are deactivated automatically. The dash panel insert displays "ACC – no sensor function". As soon as
the impairment has been rectified, the driver can reactivate ACC control.
Lets look at the components . . . .
3 - Securing nuts
q Qty. 2
q 8 Nm
4 - Retaining plate with adapter frame
q Serves as mounting bracket for adaptive cruise control unit -J428-
q With adjustment screws for adaptive cruise control unit -J428-
5 - Electrical connector
6 - Adaptive cruise control unit -J428-
q Removing and installing → Chapter
q Calibrating → Chapter
7 - Adaptive cruise control button -E357-
q Integrated in multifunction steering wheel
So thats the main section . . . .
lets look at the wiring . . . .
Adaptive cruise control unit, Onboard supply control unit, Isolation relay for powertrain CAN bus, Fuse 14 on fuse holder C, Fuse 37 on fuse holder C
J428 - Adaptive cruise control unit
J519 - Onboard supply control unit
J788 - Isolation relay for powertrain CAN bus
SC14 - Fuse 14 on fuse holder C
SC37 - Fuse 37 on fuse holder C
T8a - 8-pin connector, black, near horn, dual-tone horn
T8b - 8-pin connector, black
T9 - 9-pin connector, black
T73a - 73-pin connector, black
T73b - 73-pin connector, white
13 - Earth point, on right in engine compartment
372 - Earth connection 7, in main wiring harness
B285 - Positive connection 9 (15a) in main wiring harness
B303 - Positive connection 7 (30), in main wiring harness
B383 - Connection 1 (powertrain CAN bus, high), in main wiring harness
B384 - Connection 2 (powertrain CAN bus, high), in main wiring harness
B390 - Connection 1 (powertrain CAN bus, low), in main wiring harness
B391 - Connection 2 (powertrain CAN bus, low), in main wiring harness
So the Radar unit J428 is connected directly to the main BCM via a shunt relay,
Radar unit pinouts:
t8b/1 - 0v
t8b/8 - SC37 (fuse holder)
t8b/2 - B384 - Connection 2 (powertrain CAN bus, high), in main wiring harness
t8b/3 - B391 - Connection 2 (powertrain CAN bus, low), in main wiring harness
The isolation relay is there for security reasons so that the CAN bus is isolated from the wiring outside the main body of the van to stop CAN bus probing attacks.
The relay J788 (Isolation relay for powertrain CAN bus) connects B391 to B390 and B384 to B383 data lines together.
The relay is powered via SC14 and is 0v switched via BCM (J519) (t73a/8)
The next piece is the Buttons for the MFSW that are needed to control ACC.
Multifunction buttons on left in steering wheel, Coil connector, Alarm horn, Driver door control unit, Front passenger door control unit, Onboard supply control unit
E440 - Multifunction buttons on left in steering wheel
F350 - Coil connector, in steering wheel
H12 - Alarm horn
J386 - Driver door control unit
J387 - Front passenger door control unit
T5u - 5-pin connector, black
T10 - 10-pin connector, black, in E-box in engine compartment
T10al - 10-pin connector, red, in right A-pillar coupling station
T12ae - 12-pin connector, yellow
T16k - 16-pin connector, black
T16l - 16-pin connector, black
T17l - 17-pin connector, black, in left A-pillar coupling station
T41 - 41-pin connector, grey
B528 - Connection 1 (LIN bus) in main wiring harness
B549 - Connection 2 (LIN bus) in main wiring harness
* - Only models with electric window regulators
*2 - For models with anti-theft alarm system
*3 - Only models with no adaptive cruise control (ACC)
*4 - Only models with adaptive cruise control (ACC)
*5 - Only models with no anti-theft alarm system
*6 - Only vehicles without electric window regulators
There are other considerations and inputs but these are all picked up fron the CAN and Powertrain CAN.
The ABS, SRS, AEB, Front Assit, are all part of the system via the CAN bus.
EDIT: @dnoermann has identified that there may be two different ABS units.
Looking into ETKA, there are two different ABS Units for T6.
- SW: 7E0 907 379 Q HW: 7E0 907 379 N with ACC Support
- SW: 7E0 907 379 P HW: 7E0 907 379 M without ACC Support (City Breaking possible)
The rest seems to be just software coding . . . . .
The coding has been discussed over here: Got city braking thingy.....want adaptive cruise control...possible?
coding will be needed for the MFSW and Enable ACC with Front Assist etc etc.
ill update this thread with the definitive coding once confirmed.
Credits to:
@Pauly
@Loz
@mmi
@Adams
@New2t6
what is it?
Operating limits:
3 - Securing nuts
q Qty. 2
q 8 Nm
Radar unit pinouts:
t8b/1 - 0v
H12 - Alarm horn
Credits to:
@Pauly
@Loz
@mmi
@Adams
@New2t6
