Thanks..I meant for you to look back fut this link: Button-fix - Panel fixing made easy
Here you go:
Brilliant.Here you go:
Stainless Steel 90 Degree Right Angle Gate Latches Bar Latch Door Lock 1/2Pcs | eBay
Find many great new & used options and get the best deals for Stainless Steel 90 Degree Right Angle Gate Latches Bar Latch Door Lock 1/2Pcs at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
No worries. Let me know if you want any details.Brilliant.
Thanks mate
Thanks for your helpNo worries. Let me know if you want any details.
I had thought the cover was meant to sit on the ledge (that’s how the converter had it wedged in), but I think it’s meant to sit roughly level with the bottom.
With that in mind, I would fit this latch a little lower. And I might actually move it. It can be a little tough to get it closed at times.
These also look like a better alternative to the standard catch. They are a little more ‘visible’ than the option at #67 post. In their favour I would think there would be no need to lift the bed board engage it into the locked position as with the button. Might be easier to use?Yup. This is something I was really unhappy about.
Our converter left our cover hanging down. I was baffled… they managed to push it into place where it would stay for an entire 17 seconds. I pulled away after spending huge money on a full conversion and the cover flops down.
So I turn right back around and ask what I’m supposed to do with this.
They shrug as if to say… not our problem. I told them I couldn’t believe this is how they expect to leave it.
They then gave me the shite clips from Skyline and say they don’t fit them because they’re dangerous. I agree! But they have no alternative. Idiots.
So I did this. Found this clip on eBay and fitted it. Works well.
Spoke to guys at Skyline months later. They said they had developed a much improved magnetic system but needed to shift their remaining stock of these shitty things first. Not sure if their magnetic system is now implemented.
This aspect of my roof install I was not at all pleased about. The craftsmanship and materials for the the rest is very good.
I would still recommend a Skyline roof. I wouldn’t recommend my conversion company however.
I’ve been checking these button fix out. Since yours looks like it is mounted on the surface as mine would be now if I retrospectively used one of these, there would inevitably be a slight gap with the hatch closed. Do you have a picture of yours closed so we can see how ‘obvious’ that gap is please?That looks much better. I had mine fitted be Skyline North so you’d expect them to fit a clasp as part of the install. I ended up using something I had in the garage which I think is better than the one they sent me.
Seconded!I’ve been checking these button fix out. Since yours looks like it is mounted on the surface as mine would be now if I retrospectively used one of these, there would inevitably be a slight gap with the hatch closed. Do you have a picture of yours closed so we can see how ‘obvious’ that gap is please?
I think the runners are too short on mine as well but skyline ignored that question so I’d be interested to know whether yours are longer
That could be the reason. Since it's the main cause for the drop I'd expect them to have a solutionMaybe the correct length to ensure they are not exposed when the hatch is fully open? sharp edges etc
looks very similar, not much in it
I have been thinking of embedding a couple of these into the hatch board so they sit within a matching hole in the surround when closed.
If they don't stick out too far they will be hidden by the bed board when its slid back so no risk of catching them, plus the rounded ends will reduce chance of injury.
