Separate DC-DC and Solar MPPT chargers
Alanmh
Ok, so, I am thinking of adding a new solar panel (once I have got a new AGM leisure battery) and chances are it will have a Voc too high for the CTEK DC-DC charger and will need a separate Solar MPPT charger.
I know lots of others have done this, and despite searching, I cannot find if how it is preferred to wire the (say Victon MPPT) to the CTEK. Do i connect to the solar input (effectively two MPPT controllers in series? or something else?
Thanks in advance
Alan
Don't connect it to the Ctek, connect it to the battery directly.
Pete
Thanks in advance
Alan
I have separate mains/solar/DC-DC chargers. Everything goes straight to the battery.
Thanks for your replies. I guess I am worried about 2 intelligent charger inputs when the engine is running and the sun is shining. Doesn't seem quite right somehow.
How do you prioritise one type of charging over another in this case? I'm trying to set up a system using solar and DC-DC charging, and can't get my head round how it works (both in terms of prioritising and in regulating/protecting the leisure batteries).
I have 2 connected to the same battery each will decide if it needs to charge.
There's no need to, it largely sorts itself out. All my kit is Victron using the same Lithium profile. When the battery is charged all the chargers go into "Float". If we're on EHU & the battery drops, either the mains or solar (if there's light) will kick in. If the engine is running, the DC-DC will kick in. At the end of the day, its irrelevant where the charge is coming from, as long as it's there when needed & off when the battery is charged.
@AsInNoVolts
As above the dc_dc and solar will work individually.
Each will sample the leisure battery voltage and decide to charge or not.... Independently.
Unless you have Victron kit.... Which has a VE direct feature than enables the units to talk to each other and sync the charging.
What normally happens is when the leisure battery is low both chargers will detect the low voltage and apply full power in an attempt to charge the battery.. as the LB voltage rises the chargers will independently adjust the charge profile to suit...
Untill the LB is full, and both are in float mode.
As above ... It's important to set the charge profile to the correct battery setting that you have.
@AsInNoVolts
Unless you have Victron kit.... Which has a VE direct feather than enables the units to talk to each other and sync the charging.
Amazing, thank you so much. In that case, I'm looking at the following set up. Any chance of your thoughts on it?
- 330W SP
- Smartsolar 100/20 MPPT
- DC-DC Charger (cant work out what amp rating I need and was thining about getting victron orion in the hope it ties in a little better with mppt)
- 2x 180Ah AGM batteries
- DC-AC Inverter (can't work out how much wattage I need - its only to charge laptops and run a blender)
- Some sort of battery monitor? (is this required if i have the the victron app?)
- 330W SP
Assuming this is a camper/day van & not some kind of commercial food (smoothie) outfit, or you have a specific requirement for all that power, I think you're OTT & don't have a balanced system. IMHO, a single 180Ah battery will be plenty, a 100Ah Lithium would be even better. 150-180 Watts of solar will do the job, a 800W inverter will probably run your blender unless it's a commercial jobby.
@AsInNoVolts
see here for more info:
Dellmassive`s -- "how I Done It" -- Thread
Kit List And Stuff -- How I Done It & What I Use --
VIP Membership | VW T6 Forum - The Dedicated VW Transporter T6 Forum
For Sale - Summer-weekend-t6f Limited Edition External Stickers
For Sale - T6F Flags
Ok, I appreciate the honest advice! You are correct in assuming that this is not a commercial smoothie outfit, but it will be the permanent home for my girlfriend and I - hence why I have been planning a somewhat larger system. Though I am of course now asking myself if I should have invested in a juicer and pomegranate de-seeded...
Already got the solar panel, so sticking with the 330W, and it came with a smartsolar 100/20 MPPT, so that's also a done deal, but maybe need to reconsider the rest of the system now. If I was to stick with 2x180AH in parallel, would I have to size the DC-DC charger for 360Ah? So, (360*0.2) + the load draw amperage from the appliances ?
The lead acid batteries will only take what the DC-DC will deliver, plus you don’t want to be charging lead acids too quickly, so 15A /battery sounds fine to me. Also don’t forget that the solar will still be charging at the same time.
Sorry, my bad, they are AGM batteries...
AGM is a style of SLA or sealed lead acid.
The best version of SLA in my opinion.
The upgrade from those is lithium.
