Our alignment bay is now commissioned , we didn’t go the hunter route , it isn’t flexible enough for some of the low vehicles we want to be checking , and sometimes we do settings outside normal parameters , the new system allows us to program our own settings . It’s brilliant at setting up the power flex adjustable bushes particularly the rear .@CRS Performance
Cheers Steve - your input / comments are really appreciated.
I'm currently sat on -40mm H&R springs fitted by the original converter with standard issue Vw dampers.
At the time it was the best combination I could afford during the van purchase & money pit conversion
All 4.5 years young, at approx 22,000 miles
I'll measure arch gaps as soon as I can, but that will probably be this weekend.
Visually, it definitely sits back end heavy:
Don't know if you can remember me, but I'm the T6 driver who has already bought off you H&R arbs, drilled Nutexa discs / pads (front & rear) & have new powder coated 340mm flavour calipers/carriers for the front & the same coloured calipers/carriers for the rears.
Now I've nearly saved up some more GBP's, I'll be calling on your fitting skills early next year to install all, along with whatever flavour new springs & new dampers to suit.
Hopefully your Hunter will be up & working in your new place then, for you to breath your technical expertise (spanners & big hammer) on my Bus?
If the control arm bushes need changing, can these be done at that time or is it best to run over to you to do now?
we remember your journey so far and compliment you on your patience waiting to get the ARB s fitted. Ha ha
