I assume you didn't mention it, as a cracked head due to the extra heat/strain on a remapped ecu is just the sort of thing they would use to refuse a claim.I Hope VW don’t going to start arguing about warranty because the van is remapped.
It has been under pressure testing over the night so I am waiting on a phone call right now.
You reported the the problem whilst it was in warranty, so as long as you keep diary notes they will fix it if it turns out to be an issue.I am starting to get the feeling that VW is trying to just make some time because my warranty goes out soon.
Grommet is nothing to with coolant, they are for condense and roof gutter drains.Guys after reading these I can relate, I have a T6 dsg 2016, I have started having coolant loss and after monitoring to find the leak I have coolant dripping continuously from a rubber grommet with an outlet built into the grommet on the passenger side engine bay bulkhead. After several visits to VW Van centre they can not find the issue, and inform me that’s air con condensation, I have purposely not used the air con to satisfy myself but still water leaks from this grommet only dripping but after a good run it’s a continual drip and a puddle forms under the van.
Can any body help me with this or has anyone had the same issue.
Any help is greatly appreciated. I have attached a photo of said grommet!!!
Update: Mine's been to dealers yesterday to look at coolant loss, been told it is the EGR Cooler that's leaking, part will only arrive later this month so I have to take it back then, (been told I can drive it for now but to keep an eye on coolant) !![]()
You guessed 100% correct there !I bet they didn’t put that in writing?
Top it up and keep an eye on it.
Some mayo is normal in the filler Neck., due to a cool running engine and air flow around filler..
