CaristaJust taken delivery of a new T6 Highline Kombi. Ordered the Carista to enable me to activate the large digital mph speed display. Once I've sorted that, what else is a must do?
Cheers.
My list of must haves
Needle Sweep
Beep on lock
Flashing brake lights on emergency stop
Tear drop wipe
4 flash indicate
Australian Setting to get digital speed
Autolock on setting off
Coming home lights set to 1 minute.
Needle Sweep
Beep on lock
Tear drop wipe
4 flash indicate
Great...thanks for that.
What's the "tear drop" wipe?
I didn't activate 'Beep on Lock' because I assumed it would sound like a 1990's car alarm that hoots every time you lock the car, or am I wrong?
Mine wasn't a beep from the horn. It was just a simple a beep possibly from the alarm. It was nice to know the van had locked but didn't wanted to upset neighbours so turned it off.Its quite annoying , i lasted 2 days with it , its the beep from the horn !
I think you can stop the windows opening by holding the remote? If you can, switch it off, just gone outside to find the windows open and it peeing down with rain after carrying in the shopping
The windows should only open when you hold the unlock button down, in which case there's actually no reason to hold it down is there?
Yep it’s just like that. So annoying it lasted 20 minutes on mine, then coded it back out.I didn't activate 'Beep on Lock' because I assumed it would sound like a 1990's car alarm that hoots every time you lock the car, or am I wrong?
Tiny little chirp that means I 100% know its locked and I pressed the right button.
The loud clunk of the door locks and the flashing indicators not enough for you Pukkster?
