This much needed and never present function can be now be done without running additional cabling
This is the list of requirements:-
My van is a T6.1 - not sure again if that makes any difference.
First up we need to amend the behaviour of pin 10 in the trailer socket. Ordinary behaviour is ignition live (or more specifically engine running live I think) when trailer detected. This can be changed in the trailer electrics section in VCDS Byte 4 bit 01 as below screenshot:-
THEN this happens:- pin 10 in the trailer socket is now ignition/engine running live (irrespective of trailer present or not).
Using these pinout maps, we can determine we're looking for a gert fat 2.5mm black n red cable in J345
Now we can confirm using a multimeter that pin 10 (the big fat red n black one in the photo below) is indeed engine running live!!!!
Now all that is left for me to do is solder my take-off to charge my EcoFlow Mini!
- VCDS (possibly could be done with other software tools, but I used VCDS)
- 13 pin OEM towbar electrics (I have full OEM towbar install not just towbar prep, not sure if it makes a difference)
