H4 To H7 Upgrade
Wauw..
I can believe the ones who have changed the DRL's while in the car.. that must have been a nightmare. :eek:
I already found it to be a pretty precise job while they were in my hands on the couch. The Twenty20 DRLs are also quite a lot bigger and therefor harder to insert as well.
When you know how it is done it is quickly done (outside of the car). But that's with everything I guess.
Good thing is that you can see inside the socket and know which way around to put the DRL in. What you can do is look very good at how you pull out the previous one and put it back the same way.
Socket;
View attachment 252244testing:View attachment 252245
A h7 and h4 both connected
Difference in size: Original and Twenty20
Ps;
I Found my DRL's flikkering a bit while the car was running (in only ignition they were ok), but in both cases only 1 lamp was attached. Is that to be expected?
Here I am again, not 1 year later. Both Twenty20 are dying. Getting bulb error and de right bulb is flickering on its last breath. Not looking forward to swap them....
Any other experiences here? Alternative bulbs? Can I just have bad luck?
  • Wow
I've never had problems with mine bud, I had Osram LED ones. Just sold my H7 headlights last week, I believe to get the bulbs out its battery and airborne out
Thanks, can you share which exactly? If I remember correctly, you had to code the bulb error out on the dash?
I think I will take off the bumper.. probably quicker ...
Are you sure it is the bulbs?
Do you have the original DRL holders or the later F/G revision H7s?
And they are in:
Build in 2019, revision "F" headlights.
Very good condition
But, my TSI has an issue with one of its inlet valves, it seems to not close properly... So the joy of buying these is .. well lost. Looking at a revision of the head.
Happy that i didnt buy the THQ LEDs at the moment
Yep, see quote/pictures above, 100% sure they are the F variants.
I assume this then can't be the issue... But i might be wrong?
  • Sad
Thats what i thought... I have ask the supplier if there is a warranty possible. Since I plan taking of the entire bumper which is less frustrating then trying to peel out the bulbs and putting them in. Would be nice if I could do it all at once, bumper off, try normal bulbs, if right put in the new ones.
While installing 9 months ago I noticed that my led drl bulbs were flickering when ignition was on. When motor turned on, everything was fine. Until now.
Managed to get nearly 4 years out of mine but was hoping for 10 :confused:
It's not too difficult to replace the OS lamp, just remove the airbox, but just be careful when you pull out the holder otherwise the bulb falls into the light unit!
According to Classic Car LED's these bulbs shouldn't be used in DRL due to them burning out so I'm also looking for a more reliable alternative.
H7 Headlamp - W21W DRL Bulb Issue. Be Aware
I would sign for a couple of years... I dont know why mine are dying.
If I hear most of you talking, I wouldn't mind using them again...
Just started the H7 journey, fairly new T6 owner and a few weeks ago I drove Gospel Pass at night and FM the H4s are rubbish
Managed to find a reasonably priced revision G H7 for the passengers side but not found a reasonably priced drivers side yet. There are earlier revisions available, however, been looking for a replacement DRL bulb holder for the earlier lights and they are now £45 for 1 🤪
Fs and Gs aren't that common on ebay, lots of original and later revisions come up.
