For all of you with the standard H4 units who fancy a change from the standard DRL layout, this is how you recode with VCDS to enable your fogs/cornering lights to DRL's
What you need to do is go into central electrics controller 09 and change the following,
Byte 23
Bit 2 which is actually the third one from the end as they are counted from left to right.
As you can see there is no tick box for this option but changing it to a 1 from a 0 will produce the desired effect just make sure you then click on a different Byte (not the one with red red arrow because that is the one your changing) and this will then allow it to be saved and from there you hit, DO IT
Your fogs/cornering lights will now act as your standard DRL's behaved, i.e. when your lights or side lights these will automatically switch off but will work on cornering function and as fogs lights.
Byte 23
