Mattsuze
Hi All,
due to my limited understanding of electronics, I’m asking for some help!
I have a campervan, professionally converted T6.1 Transporter.
it has a solar panel and leisure battery with the following kit:
Victron units:
ORION TR Smart isolated DC-DC CHARGER next to leisure battery under driver seat (to charge leisure battery while driving?).
SmartSolar charge controller (MPPT 75 1 15) to charge leisure battery from solar panel.
Blue Smart charger ip22 (12 volt, 15amp, 1 output) to charge leisure battery via electric hook up ( I think).
The issue we’ve recently had is the engine battery has gone flat (low enough not to be able to start the engine) after being parked up for just 2 days.
It was a particularly hot, sunny week so solar panel worked a treat, keeping leisure battery charged. but we suspect that because we had the van doors open a lot (including all night) the van sensors were activated and this drained the engine battery (that and opening,closing doors during the day activating central locking).
We got the solar panel to avoid needing hook up But this seems to be useless if our engine battery is going to go flat!
does anyone know if the Orion tr charger can be set up (on Victron Connect or wired differently) so that it trickle charges the engine battery?
Or can anyone recommend another bit of kit that would be needed to do this. With my limited knowledge, I can only think of plugging an inverter into the leisure battery powered 12v cigarette socket in the back, plugging a car battery charger into the inverter, then connecting this via crocodile clips to the engine battery. This seems a ridiculous solution to me and would need wires feeding into the bonnet every time we park up so I hope there is a better solution than this.
would welcome any advice that could help.
thanks.
Matt
Victron units:
thanks.
Matt
