22mm/24mm od? Polylock comes in at 25mm id, others 22 and 24mm. I don't know what the corrugations are supposed to achieve as they are in no way flexible as borne out by the cracking.
24mm+ as not exactly round. 25 mm by the flange.22mm/24mm od? Polylock comes in at 25mm id, others 22 and 24mm. I don't know what the corrugations are supposed to achieve as they are in no way flexible as borne out by the cracking.
the seem to fail around 35K ish?25mm polylock flexible pipe should suit that to a T. Cut the elbow off so that there is a short stub, as long a stub as possible on the corrugated end then you can clamp it together with no need for welding even - possibly. The Polylock will permit torsion also removing all stresses on the length of it. I will have to wait for mine to fail before I try it out.
Mine at 2 years and 60k milesMine failed at about 2 years old, 18,000 miles.
What’s with the over length cap head bolt? Do VW supply that, that looks like it will be a pain in the arse to remove once the protruding threads are rusted up.Replaced by hand from the top of the car... Youtube turtorial helped...need to have small ratchet, long arms and nerves of steel and I replaced it in 40min
I think I’d be cutting those to the correct length before fitting then, plus some anti seize grease.Yes that is why Youtube tutorial helped me and I spray it with rust remover to help me with this... yes this is what VW give you. longer bolts than needed...
Only original exist... you need to buy from local VW shop...Found the problem EGR flexi pipe it has a crack in it it's the one at the back of the engine unit it's the smaller one I feel the hot air coming out of it.
Next question where can I get this part from please can anyone help
Here’s the link to the form to report a serious defect to DVSA, this is possibly the only way a recall will be forced on VW and you get the replacement EGR pipes for free.
If everybody with a failed pipe does it there might be some action.
