Dreaded egr fault and insufficient flow. I want to replace and not delete as the plan will be to sell in the coming months and grab an older t5.1.
I want to buy an aftermarket EGR and been told the pierberg is the way to go but unfortunately every website states it is not compatible...
Any advice appreciated. Please see 2 attached photos. These are of the top of the EGR front pipe of my 2018 36k mile T6.
I cleaned the area prior to a 500 mile journey after noticing a small amount of dark, tar like build up on this joint that's been there I'm pretty sure since I...
Contacted VW to request a EGR connecting pipe which I was led was part number 04L131521BH, however was told there are 2 potential parts dependant on which turbo I have installed on my van (150ps CXHA) and I would either need to get the turbo part number myself or bring the EGR pipe in to compare...
Morning, my van has started making a whooshing noise like air escaping when accelerating, seems to be coming from the left side of the engine bay. No warning lights have come on. Any thoughts would be appreciated.
Cheers
Rear small EGR modified pipe. Part No V04L131521BH and gaskets. Fitted at 46470miles and removed at 50854miles. Only changed as new modified turbo required different EGR pipe. £50 plus postage.
I've got a VW t6 102 and have a couple of issues. I recently had my egr replaced as it was blocked. since this work was carried out I have an engine fault for egr low flow. I've also noticed when I rev my engine and let the revs die off it makes a noise around the airfilter housing like a...
I have a 2018 caravelle 204 DSG with only 21000 on the clock, which has developed a crack in the rear EGR pipe, I have called numerous local garages all of whom are busy for the next couple of weeks. So I was wondering if using the van in current state will do any further damage, obviously will...
Hi all, first time poster but quickly getting used to garage bills and reading this forum!
So I bought my 2016 T6 a few months ago. I discovered the rear egr pipe was split so replaced it. I then started to get an eml with the P2006 intake manifold runner control stuck closed bank 1A code.
I...
Sorry to start another post but can’t find the answer I’m looking for.
When on boost/ under load my van has started to make a loud whistle. I have noticed for a while that it did have a bit of a hiss but on Sunday when going up hill with foot down the noise changed all of a sudden to a whistle...
Had the front EGR pipe split at the flange yesterday on me, managed to do a temp fix to get me home with some magic metal. But on removing today the end was absolutely covered in crap. Is this a normal amount to expect?
Oh and is there an easier way to get to the torx bolt on far side? It was...
Just purchased T5 Kombi and very happy so far (see photo below) only issue being there is a very strong smell of diesel coming from the inside of the cab. The previous owner very vaguely said it had been used for transporting quads etc (so there must have been other similar type engines...
T6 went into limp mode yesterday, and I checked ODB errors and it shows a 'Intake Air System Leak'.
This morning I inspected the engine bay for any obvious signs, and saw that this metal pipe had separated away from the outlet. About 10mm away. I managed to force it back in, likely a...
Selling a rear EGR pipe for a euro 6 engine.
Bought the wrong pipe, should have been the front one and then couldn't return.
In as new condition, still in the bag it came in.
I don't have any bolts / gaskets etc, was £80-odd new.
Just looking for £40 and postage on top.
Guys can someone help me, I was driving earlier today and this light has come on.
it’s only one month out of warranty, has anyone got any suggestions what it may be?? Also the cigarette lighter next to the gear stick doesn’t seem to work either but I haven’t got any idea where the fuses or...
Hi guys,
my van is making a loud hissing noise from the engine when putting my foot down and there is a huge loss of power, I'm presuming it's a boost hose? that's come off or split?
anything else i should be looking for?
there is no engine light on.
while the van is idling it won't rev above...
Hello everyone.
I Just discover this forum searching in google about the problem with my T6 and I decided to open a Post to share with all of you what happens to me and the steps I'm getting... Maybe will be interesting for someone...
My problem is that I have exhaust smells into the cab of my...
