4173Wh (330Ah) Lithium Battery Box -- How I Done It --
its that time again. . . battery box build time.
but this time i need MORE POWER,
were off camping for a 4/5dayer at the racing track - But the weather is not looking so good.
that means Solar will be poor for the recharge. . . . . and with me not having my van to connect to the DC-DC chsarger.
looks like im going to have to take as much capacity in as smaller space as possible.
for this build im going to use the Anker 757 - https://amzn.to/3NQYtf1
which is a 1229Wh beast with a built in 1500w inverter. . . . plus USB and 12v etc etc
MAIN FEATURES:
- Type of Battery LiFePO4
- Battery Capacity 1229Wh/ 384000mAh
- Lifecycle 3000+ cycles to 80% capacity
RECHARGE INFORMATION:
- Input Voltage 220-240V
- Total Input Power 1000W (AC Direct)
- EST Recharge Time with 1.5hrs (1000W)
- Use Ports While Recharging - Yes
- Direct AC Input - Yes
- # of DC Input 1
- DC Adapter - Yes
- EST DC Adapter Recharge Time 13.8 hrs (120W Car Charger)
- DC Input Size XT-60
- Solar Input Power 11-30V ⎓ 10A (300W Max)
- EST Solar Recharge Time 4.5 hrs (300W) 6.7 hrs (200W) 13.3 hrs (100W)
- Solar Panel Compatible - Yes
- MPPT Support - Yes
OUTPUT INFORMATION:
- AC Rated Power 1500W
- AC Surge Power 2400W
- Maximum Output 1828W
- AC Total Output 1500W
- # of Output Ports 9
- AC auto shut-off Power Save Mode On (2hr)
- # of USB-A Output 4
- USB-A Rated Power (per port) 5V=2.4A (12W Max)
- USB-A Total Output 48W
- # of USB-C Output 2
- USB-C Rated Power (per port) 5V=3A; 9V=3A; 15V=3A; 20V=3A (60W Max) 5V⎓3A/9V⎓3A/15V⎓3A/20V⎓3A/20V⎓5A (100W Max)
- USB-C Total Output 160W
- USB auto shut-off - Yes
- # of Car Outlet 1
- Car Outlet Rated Power (per port) 10.8~14V=10A (120W Max)
then im going to add in so extra battery power to feed into the Anker 757. . . .
the biggest battery i have around me atm is the Roamer 230Sb Gen3 - Roamer - Premium LiFePO4 Leisure Batteries for off grid
Nominal Capacity;
230Ah (2944Wh)
Nominal Voltage: 12.8V
Max Charge Voltage: 14.6V
Recommended Charge Voltage: 14.2V
Recommended Float Voltage: 13.5V
Max Cont. Discharge: 250A
Peak Discharge (10s): 500A
right so onto the build.. .
I've got the battery here . . . . but will need a box to protect it and lug about.
I've got a Magnuson Heavy Duty Toolbox spare in the shed that will work . . .
like this one. . . i got mine from B&Q the other year,
but apparently they have moved over to ERBAUER now, - Erbauer Connecx Modular Storage Polypropylene (PP) Toolbox (L)564mm (H)310mm | DIY at B&Q
as @VanDamMan recently found out when he was procuring the bits for his battery box build. . .
with the box sorted it was time to make up a fused block and connections.
it was easier for me to butcher one of my 100ah battery boxes that was spare after selling the battery. . . . .
but decided to swap out the fuse block to one that had both the POS and NEG
i went for this fuse block,
and moved over the 50A Andersons. . .
the battery terminal were the same for the ROAMER, so i left that was they were,
i also decided to remove the VICTRON SMART SHUT out the setup, as the ROAMER BMS is very capable.
dropping the battery in was a challenge. . . it was a couple of MM`s to big.
so a very tight squeeze.
next up as a opening under the lid lip for the SB50 fly leads to exit.
i used a cone cutter to make a hole. . . .
then hacksawed out a slot for the cables to fit into to hole. . .
next up was so foam protection. . . . to stop the battery moving about in the box.
i had this foam spare from a pelican case. . . . that seemed to fit the bill.
carrying on with protection it was time to cover the battery terminals. . .
i had these terminal covers to hand.
so removing the cables one at a time and sliding the cover on . . . we have protected terminals.
that that then . . . job done. .
the battery box no has two fused SB50 Anderson connectors
the idea being that one will feed the Anker to charge it, . . . so an effective OUTPUT
and one will connect to the solar for incoming sun power, . . so an effective INPUT.
both are fused at 60A MIDI fuses, as the SD50 is rated at 50A. - and the battery is capable of 250/500A power delivery. - so fusing is very important as always.
