Selling this as my power needs have changed in my van so removing this….
Comes with the original box, all cables and the manual. Couple of light scratches along the bottom edge of the unit where it has been put in and took out.
The EcoFlow DELTA mini is a portable power station that is designed for portability. It weighs only 10.7 kg and has a large capacity of 882 Wh. It can power through almost any situation with its powerful 1400 W output, which can power up to 9 devices at once. The DELTA mini can be charged quickly with its 1.6 hours X-Stream fast charging feature. It also has a 300 W solar input, which allows it to recharge in 2.5 hours12.
Here are some of the technical specifications of the EcoFlow DELTA mini:
AC Output Power: 1400 W
AC Output Voltage: 110V/120V/220V/230V/240V
AC Output Frequency: 50Hz/60Hz
AC Output Waveform: Pure Sine Wave
DC Output Power: 180W (12A)
USB-A Output: 5V/2.4A
USB-A Fast Charge: 5V/9V/12V, up to 2.4A
USB-C Output: 5V/3A, 9V/2A, 12V/1.5A
Car Port: DC 13.6V, up to 10A (130W)
Battery Capacity: 882Wh (24Ah, 36V)
Recharge Time: X-Stream Charge: 1.6 hours; AC Charge: 3.5 hours; Solar Charge: 2.5 hours with full sun.
Looking for £480 which includes approx £20 of insured courier as it is heavy.
Pics added below…
Pics added below…
