It's fine..
No problem on an AGM..
An AGM is a type of SLA battery anyway..
Sealed lead acid.
Sealed lead acid.
can the Noco GB70 be connected to an Agm battery? .... from the instructions it seems to work only with lead acid batteries ...... is it true?
All the above are lead-acid batteries - just "technologies" inside but the basic components - lead electrodes + sulphuric acid + their chemical reactions are still the same on all of them.it will work with any 12v battery.
So AGM, EFB, SLA, GEL etc etc etc....
I've had the cheaper ones before and got burned . . . . even the smaller NoCo packs. (GB40 / Soukai etc etc)And GB70 currently £135.99 at Amazon. Not quite as good as the £113 as above but still seems quite a good deal.
@Dellmassive or anyone else with experience of the NOCO - how do you think the LIDL £44.99 job would compare?
Ultimate Speed Portable Jump Starter with Power Bank -
Ultimate Speed Portable Jump Starter with Power Bank - 2-in-1: jump starter for cars as well as a powerful power bank Reverse polarity, short circuit andwww.lidl.co.uk
I've still got the Lithium cell from the GB150 that i killed in the tent last summer.My mate Matt has a Lidl one and he's started his T5 with it several times. The trick is to leave it connected for 15 minutes before starting.
As always with these things, the 12 Ah claim in the Lidl ad is deceiving - thats at the cell level (3.3v), the sum of the capacities of all the internal cells (four), which does not give the overall pack capacity. These have 4 cells in series so you can sum the total energy (watt hours) but not capacity (amp hours) - at 12v it will be at most a quarter of their claim, maybe half at USB level. This is typical of 'power bank' advertising. The Lidl wont have a boost facility, just 4 cells in series that connect across your starter battery.
I'm baffled by the energy decal on Lee's Noco 150 - 22500 joules is a piffling amount, equivalent to half an amp hour at 12v. Noco claim that the internal battery is 24wh, which is four times the 22500 joule claim but still only 2Ah at 12v. These devices take advantage of the incredibly low ESR of lithium cells allowing huge currents despite the low storage capacity. They obviously work very well and can be a lifesaver, its just annoying that the advertising claims dont make any sense at all![]()
