Sold NOCO - GB150 Boost PRO 3000A UltraSafe Lithium Jump Starter
Dellmassive
VCDS User
Moderator
T6 Master
Plus NOCO GB150 (storage/carry) official case.
VGC - as new basically. - been well looked after.
less that 10 charge cycles. (we had a few to play with)
this will jumpstart just about anything 12v,
can be used as:
Jump starter,
USB power bank,
12v Socket outlet
£199 - - collected or + postage.
Technical Specifications.
What's In The Box
GB150 Lithium Battery Jump Starter
XGC 12V Male Adapter
XGC 12V Female Adapter
XGC Extension Cable
Micro USB Cable
Microfiber Storage Bag
User Guide & Warranty Information
Starting Current
3,000 Amps (Peak)
Battery Types
12 Volt Lead-Acid Batteries
Internal Battery
88 Watt-Hour Lithium-Ion
USB Input
5 Volts 2.1 Amps Max
USB Output
12 XGC (Input)
12 Volts, 5 Amp Fast Charge (3 Hour Recharge)
12V XGC (Output)
12 Volts, 15 Amp Power Supply (i.e. Tire Pumps, Inverters, LED Lights and More)
Gas Engine Rating
Up to 9.0 Liters
Diesel Engine Rating
Up to 7.0 Liters
LED Flashlight
500 Lumens
Product Size
Height: 7.28 Inches (185.0 mm)
Width: 12.40 Inches (315.0 mm)
Depth: 2.72 Inches (69.0 mm)
Weight: 6.39 lbs (2.90 kg)
IP Rating
IP65 (w/ Ports Closed)
actual pics.
i think i might even have the original box stored away somewhere - ill have to look about for it.
